random titanium parts we weld... starting with FK8 CTR J pipe...
Old Apr 30, 2019 | 12:15 PM
exgr's Avatar
Homosexual by choice
Default random titanium parts we weld... starting with FK8 CTR J pipe...
Just going to randomly share titanium parts we make.
View this post on Instagram
Old May 3, 2019 | 08:48 AM
turbociv910's Avatar
Default Re: random titanium parts we weld... starting with FK8 CTR J pipe...
While the piece looks good, the non oem logo doesn't do it flr me
Old May 3, 2019 | 09:44 AM
Chrisfrom1986's Avatar
For a one off piece it looks cool but I'm sure that the 18 unnecessary welds considerably raises the price on a production piece. A larger logo only makes things worse.
Old May 8, 2019 | 02:54 PM
exgr's Avatar
Old May 8, 2019 | 02:56 PM
exgr's Avatar
Perhaps you didn't notice how tight the 180 turn is. There also isn't a whole lot of space and we mimic the stock profile/shape as much as possible.
Old May 8, 2019 | 03:26 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Beautiful piece man. Definitely a work of art.
Old May 8, 2019 | 05:18 PM
Klasse's Avatar
Looks nice, but can someone learn me on this lobster backing. Obviously you can adjust the radius with lobsterback but wouldn't a piece of mandrel bent pipe be way cheaper and flow better?
Old May 8, 2019 | 05:31 PM
exgr's Avatar
When the radius is really tight you have to use pie cuts. When you mandrel bend pipes you are stretching the material out. In this case, the titanium tubing is 1 mm thick. Another reason is not only can you do tight turns, you can also change the "clocking" of every piece. allowing very fine control of where the piping goes. Flow wise, when done properly pie cuts flows just as well. When possible it certainly is cheaper to do a mandrel bent piece. But for this particular case we also doing it both for aesthetics as well as fitment.
Old May 8, 2019 | 06:39 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
What machine are you using that you can pause the pulse like that?
Old May 9, 2019 | 12:39 AM
exgr's Avatar
Local Taiwan made machine called Hero Power. We use the DC version, it's either this one or very similar.
???????????? Hero Power Tech. Corp.
Old May 13, 2019 | 06:38 PM
exgr's Avatar
Old May 13, 2019 | 06:39 PM
exgr's Avatar
Old May 13, 2019 | 06:52 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Are there any advantages to this titanium pipe vs the stock AL pipe?
Old May 14, 2019 | 01:44 PM
exgr's Avatar
Stock air cleaner side ID is 60 mm (we are 65 mm)
Stock air cleaner side OD is 66 mm (we are 67 mm)
Stock piping is starting from 60 mm round then changes into semi-flat bottom oval shape then slight tapering down to 58 mm. (we are 63 mm OD 61 mm ID for the entire length of the pipe with tight radius pie cuts)
Stock turbocharger side ID is 58 mm (we are 60/61 mm)
Stock weight is 1.43 kg (3.15 lbs) we are 0.62 kg (1.36 lbs)
Titanium will transfer way less heat which means the air temperature will be significantly lower. Future revision may include additional heat shielding depending on real world data.
Old May 14, 2019 | 01:46 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Curious to see some dyno and IAT temp results,
Old May 20, 2019 | 06:16 PM
exgr's Avatar
Titanium crap...
Old May 29, 2019 | 03:55 PM
Gustav129's Avatar
I love the tiger striping! Really neat how it's done.
sLAg
Apr 21, 2012 07:20 PM
SiR-G DC
Aug 8, 2010 04:34 AM
rhdeg007
Oct 28, 2006 06:09 PM
vtecvlow
Feb 24, 2005 07:36 PM
