random titanium parts we weld... starting with FK8 CTR J pipe...
Just going to randomly share titanium parts we make.
https://cimg5.ibsrv.net/gimg/honda-t...66ace484ff.jpg https://cimg2.ibsrv.net/gimg/honda-t...bd2b2adafa.jpg https://cimg0.ibsrv.net/gimg/honda-t...3d32a5a6eb.jpg |
Re: random titanium parts we weld... starting with FK8 CTR J pipe...
While the piece looks good, the non oem logo doesn't do it flr me
For a one off piece it looks cool but I'm sure that the 18 unnecessary welds considerably raises the price on a production piece. A larger logo only makes things worse.
Originally Posted by Chrisfrom1986
(Post 51923350)
Beautiful piece man. Definitely a work of art.
Looks nice, but can someone learn me on this lobster backing. Obviously you can adjust the radius with lobsterback but wouldn't a piece of mandrel bent pipe be way cheaper and flow better?
Originally Posted by Klasse
(Post 51926952)
What machine are you using that you can pause the pulse like that?
Originally Posted by Caoboy
(Post 51926977)
https://cimg3.ibsrv.net/gimg/honda-t...d9ef81a723.jpg ???????????? Hero Power Tech. Corp. |
Are there any advantages to this titanium pipe vs the stock AL pipe?
(Post 51929987)
Stock air cleaner side OD is 66 mm (we are 67 mm) Stock piping is starting from 60 mm round then changes into semi-flat bottom oval shape then slight tapering down to 58 mm. (we are 63 mm OD 61 mm ID for the entire length of the pipe with tight radius pie cuts) Stock turbocharger side ID is 58 mm (we are 60/61 mm) Stock weight is 1.43 kg (3.15 lbs) we are 0.62 kg (1.36 lbs) Titanium will transfer way less heat which means the air temperature will be significantly lower. Future revision may include additional heat shielding depending on real world data. |
Curious to see some dyno and IAT temp results,
I love the tiger striping! Really neat how it's done.
