Why is my engine burning so much oil. Help
Hey so just recently my engine started to burn alot of oil. And started to let out blue smoke only when I sometimes I floor it. So what I did I changed the PVC valve, did a oil change, added a additive. The blue smoke has stopped but it continues to burn oil. I was thinking bad piston rings, or a bad head. Idk. Help.
Yeah, I've had great success with engine restore and also use it every oil change even though my motor only has 70k miles. But to test out your piston rings, look up how to do a dry and then wet compression test. That'll definitely let you know whether your rings are bad.
Normally I would be skeptical about any mechanic in a can, but when farm project independently tested Engine Restore with great success on their tractor I was convinced. I swear my engine fires so much quicker since using it on my Integra, I haven't put enough miles on it to test for oil consumption.
I would run a high mileage oil or just some conventional oil like Castrol GTX with a bit higher viscosity - 40 weight ? Valve seals, ovalized cylinders, and piston rings are the biggest culprits. A proper functioning pcv system helps to keep piston rings working properly.
Owe dude when my TR engine cracked a piston and the rings a long time ago I had massive blow by and the vent on my VC was shooting grey smoke. For ***** ang giggles I poured in the can lol and that sucker stopped smoking and had some power back enough that I could drive up the big hill which when before it barely drove up the hill after that I was sold on it, and my D series has like 200k miles and still runs very strong! I use a can every oil change!
A simple catch can will help as well as a new PCV valve if still using the OEM black box. Pressure is routed to the catch can and not forced through the rings and seals.
No, it's not a traditional "oil additive" that you would do that with. To my understanding, it works itself into the cylinder walls to provide a better seal and thus more compression. Just use the normal amount of oil that you usually use and then add a 4 cylinder sized can. Just make sure to shake it up first! But again for op, even though he doesn't seem to be reading his post's comments, do a dry and wet compression test to see if you need to replace the piston rings.
Jeff
Apr 30, 2005 04:01 PM
