1992 EG6 half shaft question
Old Apr 27, 2019 | 09:58 AM
MitchHamilton's Avatar
Default 1992 EG6 half shaft question
Hey guys I have a question about my half shaft. It's a 92 jdm EG6 with the jdm B16A, right now the cars automatic, doing the alternator so I pulled the axle and half shaft off. And I noticed the metal seal that sits on the outside of the transmission where the half shaft goes into is bent. Been trying to find one online and whats its called but no luck. Anyone know where I can get one? Seal is circled in red. Thanks everyone.
Old Apr 27, 2019 | 11:13 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: 1992 EG6 half shaft question
If you can’t find it, try comparing to an automatic integra half shaft.
Old Apr 27, 2019 | 11:50 AM
tony_2018's Avatar
Fish Twig
Called an axle seal.
Old Apr 27, 2019 | 11:55 AM
stin1's Avatar
Loved
Community Favorite
The axle seal is beyond that . That is a dust seal that goes over bearing on that side.
Old Apr 27, 2019 | 12:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There is no separate part number for the dust seal on the mid-shaft in the Honda or Acura catalog that I could find... so how about bending the one you have back into shape. Drill a hole in a piece of wood just slightly larger than the diameter of the shaft at the position that the ring mounts. Make a second piece of wood the same way, only cut this one in half through the middle of the hole so that you can place the two halves around the shaft between the dust shield and the mounting bracket. Then, either place the pieces into a vice and gently tighten to the desired shape (loosening so that the shaft can be rotated between the boards and then tightened again to bend that spot between the teeth of the vise), or stand the shaft up vertically and tap on the end with a rubber mallet to flatten the dust seal. The latter method may move the dust shield from it's original location, so make a mark on the on the shaft at the underside of the seal so you know where to move it back to if it ends up out of place.
Old Apr 28, 2019 | 08:47 AM
I can easily find one online and buy one, would it be the same as my auto B16? I did some research and I don't think you can buy the dust seal I'm looking for seperately sadly.
I could try that thank you, worried it'll still leak though
Old Apr 28, 2019 | 09:07 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
I am not sure, but I do know that auto halfshafts are different than manual halfshafts.
Old Apr 28, 2019 | 09:19 AM
stin1's Avatar
Loved
Community Favorite
I can attest to that. Some guy sold me a " ek9" mid shaft. Ended up being an automatic and wouldn't fit. I may still have the thing too. I can look for you op if you can't find one.
Old Apr 28, 2019 | 07:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The dust seal has nothing to do with the transmission leaking... that is the axle seal that is pressed into the transmission/clutch housing cases. The purpose of the metal dust seal on the half shaft is to minimize the possibility of something making contact with the axle seal and causing a leak since these parts are low and close to the ground and vulnerable to impact by worldly objects that commonly exist on our streets.
If you have a leaking issue, you need to look closer at the axle seal in the clutch housing.
Old Apr 29, 2019 | 01:06 PM
BiggieBert's Avatar
Loved
Community Favorite
What he said ^
Old Apr 29, 2019 | 01:55 PM
Ah okay I gotcha, maybe it started leaking cause I pulled the half shaft out a bit. Might just try to bend that seal back to original shape and see what happens. Thanks everyone for the help!
LuckyJDM
10
Feb 2, 2014 08:01 AM
mohater
27
May 21, 2008 09:45 PM
DeDonDeRosa
May 16, 2006 05:46 PM
zman
Jul 29, 2004 10:06 AM
