GSR swap, OBD 1, ECU jump shorted out, chipped P28
Old Apr 25, 2019 | 04:54 AM
WillMuniz83's Avatar
Default GSR swap, OBD 1, ECU jump shorted out, chipped P28
So yeah. I think I shorted out my Blue ECU jumper cables. I forgot to take the paper clip out and started my car. Drove it a few miles to autozone to get a new part and then I noticed the check engine light came off. I checked the ECU and saw I left the paper clip in. I replaced the part not thinking anything of it. Car was running fine until I started getting bad TPS symptoms.
I bought a new TPS. Car runs great now, but the check engine light is on and the paper clip method doesn’t work.
Im thinking I should just remove the wires from the harness, and rewriting it myself straight from the harness... I’ll probably do this next weekend. Any advice before I start hacking up my harness?
Last edited by WillMuniz83; Apr 25, 2019 at 05:05 AM. Reason: Autocorrect hates me
Old Apr 25, 2019 | 02:49 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: GSR swap, OBD 1, ECU jump shorted out, chipped P28
find out the issue before making more of a headache of the situation.
Old Apr 25, 2019 | 05:49 PM
That's the problem. I can't. I shorted out the ECU jumper so I cant pull engine codes off the CEL anymore...
Old Apr 26, 2019 | 02:28 AM
NVturbo's Avatar
O.G. triple O.G.
nothing happened to the jumper wires. Use another compatible ECU and go from there.
Old Apr 26, 2019 | 08:23 AM
mk378's Avatar
The jumper just grounds one of the ECU pins (the other wire in the jumper is the green/white sensor ground). You can backprobe the pin to see if it is being grounded when you put the jumper in. With the jumper out the voltage should be about 5 volts.
boarding2008
Aug 8, 2014 12:38 AM
93civciv
Apr 1, 2008 07:36 AM
Turboholic
Aug 25, 2004 07:16 AM
madtownhonda
Mar 29, 2004 08:09 AM
Dgr8wun
Apr 13, 2003 12:54 PM
