GSR swap, OBD 1, ECU jump shorted out, chipped P28
Old 04-25-2019, 04:54 AM
WillMuniz83's Avatar
Default GSR swap, OBD 1, ECU jump shorted out, chipped P28
So yeah. I think I shorted out my Blue ECU jumper cables. I forgot to take the paper clip out and started my car. Drove it a few miles to autozone to get a new part and then I noticed the check engine light came off. I checked the ECU and saw I left the paper clip in. I replaced the part not thinking anything of it. Car was running fine until I started getting bad TPS symptoms.
I bought a new TPS. Car runs great now, but the check engine light is on and the paper clip method doesnít work.
Im thinking I should just remove the wires from the harness, and rewriting it myself straight from the harness... Iíll probably do this next weekend. Any advice before I start hacking up my harness?
WillMuniz83 is offline
Old 04-25-2019, 02:49 PM
O.G. triple O.G.
NVturbo's Avatar
Default Re: GSR swap, OBD 1, ECU jump shorted out, chipped P28
find out the issue before making more of a headache of the situation.
NVturbo is offline
Old 04-25-2019, 05:49 PM
That's the problem. I can't. I shorted out the ECU jumper so I cant pull engine codes off the CEL anymore...
Old 04-26-2019, 02:28 AM
O.G. triple O.G.
NVturbo's Avatar
nothing happened to the jumper wires. Use another compatible ECU and go from there.
NVturbo is offline
Old 04-26-2019, 08:23 AM
The jumper just grounds one of the ECU pins (the other wire in the jumper is the green/white sensor ground). You can backprobe the pin to see if it is being grounded when you put the jumper in. With the jumper out the voltage should be about 5 volts.
mk378 is offline
  • Ask a Question
Question Title:
Description:
