Reverse Light Issues - K-swap 1997 Civic LX 5-speed
Hello all,
This is my first real post as I'm mostly just a lurker as all of my questions have been answered up to this point... So, my problem is that my reverse lights do not work. The car is a factory 5-speed so it doesn't have anything to do with an auto conversion. I have swapped in a jdm K24A and I'm using an EP3 Si trans. I have verified that the reverse switch on the trans works, the harness gets power, the fuse is good, and I have traced the wires for the reverse lights through the entire car and have not came across any obvious breaks or issues. I do know that there is no power at the harness where it connects to the trunk/package tray harness, meaning that it has to be between the fuse box and the plug next to the rear driver side door. I have yet to take the fuse box out, but I suppose that's the next thing on my list. I'm just hoping that someone will have another suggestion or an idea that I have missed.
If this has been answered, I promise I have not found it, it's been two weeks of searching and experimenting and I'm frustrated like no other...
Thank you guys in advance,
Adam
I should also throw in that everything else on the car seems to work fine, including the taillights.
Adam
Power should be at the back-up lights at ALL times when the key is turned on.What illuminates the back-up lights is the ground wire when summoned. This occurs when the reverse switch is closed. So, first you will need to check and verify the continuity between ground and the rear back-up light plugs. Also, make sure that there is 12v+ on the other wire of the plug/socket.
That was my first inclination, but I have not found any blown fuses, I've pulled all of them, as far as I know.
Check the bulbs if you haven't already.
I thought the switch was in the live side of the circuit, and the fuse is the same one that runs the turn signals.
Turn key on, engine not running, shift to reverse, both wires of the reverse switch should be live. If the wire in the trunk is live but not at the sockets, it is likely a broken wire where it crosses from the body of the car to the trunk lid. The sockets also have a ground wire which can break the same way.
Sorry for bumping up old thread but I got some issues with the reverse light after K swapping my EG. So shortly the car was D15b2 converted to mpfi from D16a9. After the K swap when I put in reverse my charge light comes on... I am using labeled chinese conversion harness and wiring is all like it's supposed to be. Everything else works spot on fuel pump,fan switch etc. So the blue wire from the conversion harness goes to the b10 with the white blue one on the original K engine harness, without cutting it only tapped into. I've also checked the strut tower connection of the conversion harness and it goes blue to white blue on the original one. Also checked a friend of mine with the identical swap and his is the same. Any help will be appreciated! Thanks in advance. Btw the car is OBD0 from the factory.
crazyLemons4.20
12
May 29, 2013 06:43 PM
RIZOBIZERT
Honda Civic (2001 - 2005)
Dec 1, 2007 05:13 AM
