2000 Accord F23a - Is this a plug Or Knock Sensor?
Old Apr 15, 2019 | 08:30 PM
pieceofcloth's Avatar
Default 2000 Accord F23a - Is this a plug Or Knock Sensor?
Hello. I recently replaced my motor from my 2000 Accord. The original motor was an F23a1. I purchased a JDM F23a & noticed my harness would not connect to the rear of my block. This is the last connector & was wondering, "was it ever hooked up in the first place?" I'm not to sure because my original motor looks the exact same & I feel like I overlooked it when I was removing the harness connectors to get the original motor out.
Is this some sort of plug &/or does it need to be connected? My connector from the harness does NOT look anything that will fit/work with it. All help is appreciated. Thank you.
original motor (pulled ) f23a1
new motor installed - f23a
new motor installed - f23a closeup
Old Apr 15, 2019 | 10:51 PM
Aradin's Avatar
Premium Member
Default Re: 2000 Accord F23a - Is this a plug Or Knock Sensor?
It's the knock sensor. They're almost always broken on the JDM take out engines.
Old Apr 16, 2019 | 08:13 AM
2171USMC's Avatar
knock sensor but pull it to see if it's plugged? We broke mine but when we took it out, it was plugged.
Old Apr 16, 2019 | 08:40 AM
Thank you guys for your fast reply/info/time
brian camilo
Apr 12, 2016 05:28 AM
VeeSykkz
Apr 30, 2013 12:23 PM
DougieStyle
Jul 17, 2006 06:10 AM
(JON)
Dec 3, 2003 06:05 AM
