What size injectors would be best for a b18a1/b1 turbo build
Old Apr 7, 2019 | 09:55 PM
Richardvr1's Avatar
Default What size injectors would be best for a b18a1/b1 turbo build
Hi guys I'm trying to figure out what size injector would be best for my b18a1 build I have a fish scaled crank wiseco 8.6:1 com 8.3:1 compression pistons golden eagle rods apr2000 rod studs and bearing for the bottom end a b18b1 head with forged valves and springs with 282 turbo cams with a ported intake and a 70mm skunk throttle body I have a 60 trim turbo trying to get the best build out of it my first turbo build so I need a little help?
Old Apr 8, 2019 | 03:24 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: What size injectors would be best for a b18a1/b1 turbo build
Your horsepower goal will determine your fueling needs. There are lots of fuel injector sizing calculators on the internet. Make sure you give yourself some safety margin on duty cycle.
Old Apr 8, 2019 | 04:42 AM
Txdragon's Avatar
^^ This..
If you're just looking for an answer to a question, get 1000cc and call it a day.
Old Apr 8, 2019 | 07:03 AM
Schister66's Avatar
Man U FTW
Assuming T3/T04e 60 trim, you're capped at about 450whp, so with that you need about 6cc/whp.
450 x 6cc = 2700cc total
2700cc / 4 injectors = 675cc minimum.
With that, i'd go for either 720s or 880s. If you plan to make more power in the future or if you switch over to e85, it might make sense to pick up a set of 1000s right off the bat.
Old Apr 8, 2019 | 09:22 AM
K20.ek's Avatar
Originally Posted by Txdragon
^^ This..
1000cc FTW!!
Old Apr 9, 2019 | 02:44 AM
NVturbo's Avatar
O.G. triple O.G.
1000cc + E85
Richardvr1
Apr 8, 2019 05:36 AM
West Werks
Dec 11, 2009 06:25 PM
jusholeum
May 13, 2009 11:41 AM
dc2_and_ef
Nov 1, 2003 01:16 PM
Project_SOHC_EX
Mar 5, 2002 11:32 AM
