Throwing Code but doesn’t show on hondata ?
Old Apr 5, 2019 | 08:39 AM
Randomnoob's Avatar
Default Throwing Code but doesn’t show on hondata ?
I have a 99 ex coupe with a high comp jdm b20b in it. On the chipped ecu There was no codes and ran fine on basemap. I put my hondata s300 v3 ecu in and my engine light comes on but no codes show up ? I was able to data log and everything. 2step is set up. I have Duralast plug wires and Ngks spark plugs could that be the issue ?
Old Apr 5, 2019 | 10:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Throwing Code but doesn’t show on hondata ?
What ECU platform ??? What basemap are you using ??? Usually, a "phantom code" is created from an ECU/program conflict. For example, you have the knock sensor turned on in your basemap program but the ECU is a P28... which has no knock circuitry and thus, no code for knock exists in the ECU's trouble codes library, yet the program looks for it. The program detects the missing sensor, but the ECU cannot identify what is missing.
Old Apr 6, 2019 | 06:44 AM
Randomnoob's Avatar
My chipped ecu was a p75 with a b20 basemap . I put the hondata in a p06 I believe(or other way around) Ill double check when I get home But I had someone clean it up( Not some random dude on fb) till Im ready for an actual tune . Although On the chipped ecu My idle would hunt here n there.
Old Apr 6, 2019 | 05:26 PM
Randomnoob's Avatar
Just got home and It was the p75 we put the hondata in. P75 doesnt look for knock sensor , so is that what you meant by the ecu having No knock circuitry/No code exists in the ecu trouble codes library ?
Old Apr 6, 2019 | 05:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Exactly. Double check your tune and make sure that the Knock sensor is turned off in the program.
Old Apr 7, 2019 | 09:57 AM
Randomnoob's Avatar
knock sensor is turned off from what I see , I can double check the sensors and see whats on and off. Any other ones that’ll throw a phantom CEL?
Old Apr 7, 2019 | 05:48 PM
tony_2018's Avatar
Fish Twig
good point, i'll keep this in mind
Old Apr 7, 2019 | 09:13 PM
Randomnoob's Avatar
Knock sensor is off, Vtec pressure is on but everything eles for vtec is off, he said that it should still disable the vtec ? Is he wrong ? Its still searching for it ? 😥
Old Apr 7, 2019 | 09:21 PM
K20.ek's Avatar
Try to erase the ecu and reload the map. The b20 baseman shouldn’t be looking for vtec.
redtegsr
Jul 14, 2007 02:44 PM
fidget15
May 24, 2006 02:45 PM
RAS Motorsports
Nov 3, 2004 08:54 AM
dav3ddt
Jul 7, 2004 06:37 AM
TRhatchCRAP
Aug 27, 2003 07:01 AM
