Classic Hondas All Pre-1988 Hondas.
1983 civic 1500cc head bolts
Old Apr 2, 2019 | 08:43 PM
cuda70gt's Avatar
Default 1983 civic 1500cc head bolts
i am building a 1983 honda 1500cc engine in a civic.
i am putting the head on and noticed all the bolts are the same length except one which is sorter.
would anyone know where the short bolt goes?
Old Apr 24, 2019 | 05:22 PM
GrumpyOne's Avatar
Default Re: 1983 civic 1500cc head bolts
First, I hope that you have the shop manual. Second, I've been fiddling with Gen II Civics for over ten years and have never come across this issue. Just how much shorter is this bolt?
With that said, I am not aware of a "shorter head bolt" so I suspect that the odd one is not original. OTOH, new head bolts are unobtainium but it's OK to use the old ones.
Old Apr 24, 2019 | 05:41 PM
cuda70gt's Avatar
yes i have a shop manual.
the short bolt is about 1/2" an inch shorter than the rest.
i am 100% sure the shorter bolt is OEM Honda, this engine has never been apart and the head has never been removed until i pulled it.
yes i agree, re-using the OEM bolts is fine, if its not broken why replace it.
Old Apr 25, 2019 | 11:03 AM
HondaJax's Avatar
Old Apr 25, 2019 | 11:06 AM
HondaJax's Avatar
I think it goes here. I ran into the same issue a couple months ago. If you look at the head all the bolt locations but one will be the same height. I think the short one goes under the starter gear. Good luck
Old Apr 25, 2019 | 04:13 PM
cuda70gt's Avatar
ok, thanks buddy, i didnt notice that, i will try it.
esombra23
10
Mar 1, 2015 11:22 AM
crazykarlnow
Suspension & Brakes
Sep 1, 2007 11:20 AM
SiB16A
Sep 20, 2004 06:06 PM
1bar
May 12, 2004 10:33 PM
