Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Time duration on track per tank of fuel?
Old Mar 5, 2019 | 11:01 AM
Dancing is Forbidden's Avatar
Default Time duration on track per tank of fuel?
Hello, we have a Civic Sedan track car with a stock internal B18c1 and ITR transmission. We have done a few endurance races with it and I feel like we're just using too much fuel. The engine is dyno tuned and not running rich and maybe, if anything, a bit lean. After an hour of racing we're having to put in 10 gallons of fuel to fill it back up. Does this seem too high? If not, thats ok, I just want to compare to others.
Thanks
Old Mar 5, 2019 | 11:15 AM
ross2004's Avatar
Default re: Time duration on track per tank of fuel?
8.5 gal/hr at VIR, roughly 200 crank hp.
Old May 17, 2019 | 06:25 AM
sjg88's Avatar
5 Year Member
seems normal.
ive torched 5 gallons of gas in 1 HPDE session and it was more or less empty by the end but i suspect my fuel sending unit is alittle off as the car is old and has high miles
im running a stock gsr motor w/ a 9 lb fly wheel.
Old May 17, 2019 | 07:38 AM
90civichbsi's Avatar
3 20 minute or 2 25-30 minute sessions empties 3/4 of tank for me which is about the limit of how low I can go without fuel starving in long corners. I get about 7-8 miles per gallon on track. 300hp b16 turbo though
Old May 17, 2019 | 10:12 AM
Dublocivic's Avatar
Thanks
I got 3 20-25 minute sessions out of 10 gallons of E85 with ~260 whp NA K24A. I would suspect that on 93-110 octane 4 sessions would be possible. What kind of fuel?
Old May 17, 2019 | 01:32 PM
iwannarace's Avatar
I bet one full tank in the GSR (stock jdm b18c) would last all day / 4 - 20 minute sessions. but I usually refill after the third session for piece of mind.
Old May 17, 2019 | 01:34 PM
iwannarace's Avatar
sorry, quick off topic...
@90civichbsi what turbo (model/specs) are you using?
Old May 17, 2019 | 01:56 PM
I've had the same basic turbo setup since 2004. 50 trim Garrett t3/t4 w/.63 a/r @10psi making 305 to the wheels. (stock b16a1 aside from ARP head studs)
When this turbo gives out I'll probably swap to more modern design, likely a BW S252SX-E if i stick with journal bearing or look into the new Garret G series G25-550 turbo if i decide to fork out the money for a ball bearing.
Old May 20, 2019 | 01:10 PM
TerraVista's Avatar
Default Re: Time duration on track per tank of fuel?
Been fielding a CRX in Lemons/WRL for the past 5 yrs. Both the D16y8 and B16 get about 1:45-1:50 out of 11.5 gallons. I really wish we could hit the 2:00 mark. I would try to lose some weight, and make the car more aerodynamic/slippery.
Keeping the revs down also helps, but that isn't any fun.
Old May 23, 2019 | 04:02 AM
Kaan's Avatar
Loved
Community Favorite
it all depends on the track... I get a lot better fuel economy at Summit than I do VIR... the long straights have something to do with burning more fuel (go figure).
gearing has a lot to do with it... when I was on a 4.4 FD and using gears 2/3/4/5 (a lot less of 5) I wasn't burning nearly as much fuel. now with the 4.928 FD I'm burning about 9 gallons/hr at VIR and about 7.5 gallons/hr at Summit.
Charlie Moua
Aug 3, 2016 01:48 PM
miamirice
11
Feb 17, 2014 12:41 PM
Black R
Jun 26, 2004 11:49 PM
speedracer33
34
Nov 7, 2003 02:25 PM
L'motaHB
Sep 11, 2003 10:52 AM
