the downfall on running low on gas..
Old Sep 9, 2003 | 12:39 PM
L'motaHB's Avatar
Default the downfall on running low on gas..
i know running almost empty is bad, but would like to know what it actually doest to the motor/car. thanks in advance to whoever knows.
Old Sep 9, 2003 | 12:43 PM
rsbad454's Avatar
Default Re: the downfall on running low on gas.. (L'motaHB)
i guess more of a chance of sucking up sediment in the tank........
Old Sep 9, 2003 | 01:32 PM
Highrevs99's Avatar
Mostly it will effect the fuel pump . The pump being sumerged in the fuel is what helps cool fuel pump motor . Over the long run it will deteriate the motor and cause it to fail .
Old Sep 9, 2003 | 01:59 PM
ShiroX's Avatar
Default Re: the downfall on running low on gas.. (Highrevs99)
ding ding ding ding I think we have a winner!
Old Sep 10, 2003 | 11:13 AM
PupaScoopa's Avatar
Default Re: the downfall on running low on gas.. (VTeC4TheChildren)
That and the fact that if you have fuel starvation on a track... you may get a surge/cut in power and fly off the track. I've seen it, not fun.
Old Sep 10, 2003 | 11:16 AM
sackdz's Avatar
Default Re: the downfall on running low on gas.. (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">That and the fact that if you have fuel starvation on a track... you may get a surge/cut in power and fly off the track. I've seen it, not fun.</TD></TR></TABLE>
Almost happened to me last race
Old Sep 10, 2003 | 02:49 PM
3gdude's Avatar
Default Re: the downfall on running low on gas.. (sackdz)
On the flipside, gas weighs about 7lbs a gallon....12 gallons is about a 100 lbs...small engines dont tote weight very good. When you go to the track it becomes a factor.....3gdude
Old Sep 11, 2003 | 02:31 AM
ptrainernla's Avatar
The Other day I was driving on 'E' on the freeway. I had filled up the tank and got about 235 miles before i got back to 'E'. After getting off the freeway i noticed the car idling really eratically as if it were going to cut off and then it would surge ( i would hear the throttle open for a sec). I filled the tank back up and raised the idle a lil but still the engine does the same thing, just not as bad (meaning i does not sound like it is going to cut off). Another unwelcome outcome I have recieved with this turn of events is that I have only drove about 50 miles so far after filling up and now im at half tank.
This is a stock 1988 civic 4dr 1.5L with Dpfi.
I was told that it may be the fuel system.
Old Sep 11, 2003 | 05:32 AM
LudeyKrus's Avatar
Default Re: the downfall on running low on gas.. (ptrainernla)
Bad example, but still....
On my old Honda motorscooter, the gas tank rusted a good bit on the inside, and everytime I let it run empty, it would suck up the rust at the bottom of the tank, and I'd have to take off all the lines and filter and clean/blow it all out.
It's possible you sucked somethin up.
Old Sep 11, 2003 | 09:34 AM
SpyderZEX's Avatar
Default Re: the downfall on running low on gas.. (LudeyKrus)
I have also heard that, when you let the tank run low, it allows water moisture to build up in the tank. This causes the tank to rust on the inside. I don't have any personal experience to back this information up, but it was what I was told when I was younger. I'm not sure if this is even possible, but some of you other guys can let me know if I'm wrong.
Old Sep 11, 2003 | 10:52 AM
tha Big EZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptrainernla &raquo;</TD></TR><TR><TD CLASS="quote">
I was told that it may be the fuel system. </TD></TR></TABLE>
maybe its just the fact that it is a 88 civic...
Psychoteen101
Sep 9, 2016 10:47 AM
Johnny_Rocket
Honda Motorcycles
11
Jan 23, 2009 07:29 PM
Tyson
Honda S2000
31
Mar 2, 2007 03:44 PM
faSHOwidIT
Apr 7, 2005 03:36 PM
91integraLSVTEC
Oct 26, 2003 07:52 PM
