Help!!!! Crank angle sensor code wont rev over 3k
Old Nov 14, 2002 | 06:12 AM
NWAS's Avatar
Default Help!!!! Crank angle sensor code wont rev over 3k
I just replaced my pistons and rods in my B16 2nd gen, code #4. crank angle sensor. tried a different dist and same prob. Any suggestions?
Old Nov 15, 2002 | 05:48 PM
dr650's Avatar
New User
Default Re: Help!!!! Crank angle sensor code wont rev over 3k (jdmsicivic)
check your timing<<<
Old Feb 15, 2005 | 07:59 PM
92HB_HB's Avatar
Default Re: Help!!!! Crank angle sensor code wont rev over 3k (dr650)
i've got the same problem..
code 4 and the car won't rev over 3.5 K rpm...
Old Feb 15, 2005 | 11:23 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr650 &raquo;</TD></TR><TR><TD CLASS="quote">check your timing&lt;&lt;&lt;</TD></TR></TABLE>
Old Feb 16, 2005 | 09:17 AM
Jago's Avatar
Default Re: Help!!!! Crank angle sensor code wont rev over 3k (NWAS)
what year car is that.
Old Feb 19, 2005 | 06:29 PM
92HB_HB's Avatar
Default Re: Help!!!! Crank angle sensor code wont rev over 3k (Jago)
well, i marked my dizzy b4 i took it off.. so timing should be good.. i also rotated the crank several times and the cams are dead on..
Even swapped my bro's gsr dizzy too, and I still get the code 4..
this is really getting to me..
Old Feb 21, 2005 | 06:36 AM
JimBlake's Avatar
Default Re: Help!!!! Crank angle sensor code wont rev over 3k (92HB_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">Even swapped my bro's gsr dizzy too, and I still get the code 4...</TD></TR></TABLE>That kinda says it's the wiring from the distributor to the ECU. Remember the signal leads from the 3 sensors are shielded, at least for some years. So if anybody tried splicing things, check to see if the lead is shorted to the shield.
Old Feb 21, 2005 | 06:51 PM
92HB_HB's Avatar
Default Re: Help!!!! Crank angle sensor code wont rev over 3k (JimBlake)
<U>UPDATE</U>
It turns out my ECU is F'ed up, NO good anymore..
I took my ECU and swapped it in my brothers gsr.. and got the same code 4.. when i put his ecu back in, there was no code.. THat right there proved to me that the ecu is fried..
This really sucks.. now i have to find me another ECU and rechipp it for hondata..
Old Feb 22, 2005 | 03:55 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">It turns out my ECU is F'ed up, NO good anymore...
</TD></TR></TABLE>Just for grins, check out the harness sockets on the ECU. Just to rule out a bent or broken pin where the harness plugs in. Maybe you can fix something like that?
crxfreak1117
Nov 22, 2007 02:40 PM
b18bcrxhf
Nov 30, 2006 01:23 AM
95greenteg
May 20, 2006 08:41 PM
crx-t
Aug 1, 2004 08:04 AM
mraudio13
Sep 19, 2002 05:34 PM
