Brake help
Old Feb 27, 2019 | 07:16 AM
plumdusty's Avatar
Default Brake help
I have a 96 Civic DX coupe. I am experiencing an issue with my brakes. When I brake the pedal nearly goes all the way to the floor. I have put on new brake pads and a new master cylinder. The brakes have been bled and have filled the brake fluid. What else am I missing?
Old Feb 27, 2019 | 08:00 AM
NukeNinja's Avatar
Default Re: Brake help
You missed the calipers.
Old Feb 27, 2019 | 08:03 AM
BiggieBert's Avatar
Loved
Community Favorite
Haha you ninja editor you!
OP, check your calipers to make sure they aren’t leaking, Also, did you bench bleed your MC before connecting to the system? If not, there is air in the mc.
Old Feb 27, 2019 | 03:42 PM
mk378's Avatar
One of the rear drum brakes could be failing to self-adjust. How well does the hand brake work?
Old Feb 28, 2019 | 04:46 PM
muellersfan's Avatar
It's easy to have air still trapped in the hydraulic system, even after bleeding, especially if you bled the system incorrectly.
You also must bench bleed the MC.
xkrazyxjbrkerx75
13
Jul 16, 2011 04:27 PM
mshields4129
Jun 18, 2011 06:18 PM
blu3g
Apr 22, 2006 10:36 AM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
