“Sleeved” block opinion identification
Old Feb 16, 2019 | 06:49 PM
spoonhbk11's Avatar
Default “Sleeved” block opinion identification
I need opinions if sleeved “block”...
Old Feb 16, 2019 | 06:52 PM
spoonhbk11's Avatar
Default Re: “Sleeved” block opinion identification
theshodan
Old Feb 16, 2019 | 06:55 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Use the @ sign to tag somebody
@TheShodan
Old Feb 16, 2019 | 07:08 PM
spoonhbk11's Avatar
Ok thanks
Old Feb 16, 2019 | 07:33 PM
spoonhbk11's Avatar
Need a quick reply please
Old Feb 16, 2019 | 08:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
We need a closer shot of the sleeve material to tell you for sure. Does the sleeve appear to be the same color ??? Stock sleeves are only steel about .060" thick... which means you essentially have a "dark ring" close to the center of each cylinder bore and then a lighter outer aluminum sleeve surround. A "sleeved" block will be the same color all of the way through.
Old Feb 17, 2019 | 05:33 AM
TheShodan's Avatar
Moderator
I concur with JRCivic1.. We have to see more. But I can say that After looking closer into this image, i can see something in the middle of the sleeve that appears to be a copper o-ring. But this block needs to be a little cleaner to be certain.
That's all I can/will comment on without more information and better images
Old Feb 17, 2019 | 09:10 AM
spoonhbk11's Avatar
Old Feb 17, 2019 | 10:02 AM
TheShodan's Avatar
Moderator
After this FB post, this is definitely a block guard.
Old Feb 17, 2019 | 10:41 AM
spoonhbk11's Avatar
I don’t know man sounds legit from what I know... “sleeved” at magnum performance... “here say” that is but other tuner guy I know claims it’s sleeved. B18c 84mm.Plus, does look like a center line mark in between each sleeve. I’m curious as to why you think block guard
Old Feb 17, 2019 | 10:44 AM
spoonhbk11's Avatar
Old Feb 17, 2019 | 11:33 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Did they paint the caps?
Old Feb 17, 2019 | 12:29 PM
spoonhbk11's Avatar
Old Feb 17, 2019 | 02:20 PM
TheShodan's Avatar
Moderator
There were some signs of sleeves i thought i saw earlier and the after closer inspection of the other photos, the spacing outer sleve protector looks like a guard.
I dunno, you're gonna have to **** or get off to pot to find the real answer to this puzzle, my friend.
Old Feb 17, 2019 | 06:30 PM
Chance EG's Avatar
If there's ever doubt over this sort of thing, I always advise to err on the side of caution.
Pointless to try to save a few hundred dollars on a "sleeved" block to find out the walls aren't what was wanted or needed, and have wasted money on internals and assembly in the process of trying to make it work.
Old Feb 17, 2019 | 09:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
From the Facebook photos, I believe it is sleeved. I still haven't seen a close enough shot to say definitively that it is in fact sleeved, but based on these photos... I would say 80% sleeved. The blockguard portion appears to be segmented and that suggests that the sleeve and the blockguard are one piece per cylinder and are therefore likely machined into the block.
TravisBiggie
Oct 18, 2013 05:08 AM
ILLUSTRATED_EM1
Nov 21, 2008 01:47 PM
djnikko
Sep 16, 2004 03:12 PM
hbvetteslayer
Jun 26, 2003 08:56 PM
satan_srv
Mar 19, 2003 01:52 PM
