Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Lost 5v reference for TPS, etc
Old Feb 15, 2019 | 03:19 PM
turnert3's Avatar
Icon5 Lost 5v reference for TPS, etc
2004 accord lx 2.4l manual. Lost 5 volt reference to tps and other sensors along with this checked coming out of computer and have nothing. I've ohmed out engine wiring harness and have found it to be good, once plugged in I have no voltage. I've tried a spare ecu also and had the same problem. Any ideas?
Old Feb 15, 2019 | 03:49 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Lost 5v reference for TPS, etc
Check power and ground going to the ECM/PCM.
  • Check under-hood Fuse No. 8 (15A). This is hot at all times.
  • Check under-dash Fuse No. 19 (15A). This fuse get power when the ignition switch is in the ON or START position.
You may have to backprobe the wire terminal connections.
  • With the ignition switch in the ON position, is there power (battery voltage) at the Blk/Yel wire terminal no. 9 at ECM/PCM harness Connector E?
  • With the ignition switch in the ON position, is there power (battery voltage) at the Yel/Blk wire terminal no. 2 at ECM/PCM harness Connector A?
  • With the ignition switch in the ON position, is there power (battery voltage) at the Yel/Blk wire terminal no. 3 at ECM/PCM harness Connector A?
  • Is ground wires and connection at G101 okay?
austinramsay
Jul 12, 2014 11:01 AM
thatasiankidtony
Audio / Security / Video
Nov 7, 2006 02:18 PM
AznMTboy
Jun 2, 2005 12:10 PM
flip1199
Mar 13, 2005 08:45 PM
tzenisj
Mar 19, 2004 05:39 AM
