Checking in before the rebuild (D15Beast7)
Old Feb 11, 2019 | 09:22 PM
oldman9's Avatar
Default Checking in before the rebuild (D15Beast7)
At the advice from Tomcat39, I've been digging into the search bar for D15's with an A6 cam and Y8 gear. Both of which I can get for dirt cheap.
This car is a daily driver that is never going to see boost or juice. It's been doing 40 miles per day 6-7 times a week for years.
I wanted to make a list of things I've already got waiting and see what I might have forgotten or just not even thought of.
I have a 1995 civic LX with the mostly stock D15b7. A noisy S20 5 speed.
What I've replaced in the last year that will not need replaced
All cooling sensors.
Radiator and thermostat
Long-tube header
Gutted cat with a full 2 1/2 exhaust
Shockingly quite Thrush turbo muffler
All front suspension parts
New CV axles
4 high carbon brake rotors with ceramic pads
What I've bought in preparation for the rebuild.
Main bearings
Connecting rod bearings
Thrust washers
Stock piston rings
Master engine gasket kit
Multi-layer steel head gasket
Complete timing set
Replacement cooling fan
O2 sensor, the current one looks like its from an old diesel engine
Brand new Torque wrench as I caught my kids using my old "good one" as a hammer.
I'm having the block, head, connecting rods checked, cleaned, prepped at a machine shop.
I have a friend with another s20 trans that has less than half the miles mine has. I'm getting that with
engine mounts and a exedy stage 1 clutch.
Is there anything I'm forgetting?
Old Feb 12, 2019 | 09:08 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Checking in before the rebuild (D15Beast7)
figure out what bearings you need before ordering.
Old Feb 13, 2019 | 05:55 AM
BryanM.'s Avatar
Resident Gearhead
Spark plugs
Cap & rotor
Check plug wire resistance
Consider a clutch slave cylinder since they are cheap and easy to repalce with the engine out of the car
GoatBible
Sep 26, 2015 08:24 PM
z6boost
Jan 16, 2009 04:56 AM
blakacintegra
Oct 25, 2006 08:17 AM
birz
Mar 1, 2004 03:30 PM
honda93
Jan 12, 2004 12:00 PM
