Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic with SRS light
Old Feb 9, 2019 | 11:38 AM
uoficowboy's Avatar
Default 2001 Civic with SRS light
My 2001 Civic recently turned on its SRS light. I used an OBDII scanner and read out a P1298 code. Apparently that's a bad ELD. I tried resetting the code but it came back immediately.
I replaced the ELD and the code went away without me even having to reset it. Repeatedly reading out the codes yields zero codes every time.
But SRS light is still on.
Any suggestions?
Old Feb 11, 2019 | 05:22 AM
NDNV's Avatar
Default Re: 2001 Civic with SRS light
You will need to get the SRS code scanned using a proper scan tool that reads SRS codes. Most standard scanners will not.
Old Mar 8, 2019 | 05:48 AM
MQAcuraEL's Avatar
An OBD scanner will not read srs codes. The code you read was a malfunction code
https://www.troublecodes.net/p1codes/p1298/
To read SRS codes, the easiest way is to insert two paper clips into the 4 and 9 positions of your underdash OBD interface, connect them, turn ignition key to II position and then count the blinks of your srs light. Here is info for how to do it
https://forums.clubrsx.com/showthread.php?t=636707
Old Mar 8, 2019 | 08:38 AM
MQAcuraEL's Avatar
Just do a search for how to read SRS codes. There have been extensive threads written for how to do so both here and in an RSX forum. I posted a link in a reply earlier with a how to and a list of the codes and how to decipher them, but somehow that got my comment sidelined awaiting moderation. Its easy to do and requires no special equipment other than two paperclips.
Old Mar 8, 2019 | 08:53 AM
It Wasn't Me's Avatar
It's an effort to keep noobs from spamming the place.
It'll either be approved by a moderator or eventually appear after your Trial User status expires. (usually within a couple weeks after joining)
Old Mar 8, 2019 | 09:19 AM
MQAcuraEL's Avatar
Yeah, I have seen that happen on other forums. Usually, a new member cannot post links or pics so as to cut down on spam accounts. Anyhow my latest answer did appear. No point leaving a thread hanging with wrong information. The simple fact is you do not need a special scanner to read SRS codes on a 7th gen Honda Civic, and the how-to info is available in this very forum.
deanwashere
Jul 25, 2018 04:28 AM
96civic909
Sep 11, 2012 06:06 PM
-Todd-
Mar 25, 2006 02:13 PM
ultraforce77
Aug 7, 2004 10:17 AM
