*video* what SRS code is this
Re: *video* what code is this
Honda will typically store up to three blink codes. You have code 51 and code 11 twice. Code 11 indicates a problem with the drivers side airbag. Could be an airbag or the clock spring. Code 51 indicates an internal error in the SRS control unit. I would reset the trouble codes and see if the code 51 returns, with any luck it won't.
This is the procedure to reset the light.
You can use a paperclip in place of the scs service connector. MES is located in lower left dash and is a 2 pin with grey grey or green green wires
Turn the ignition switch ON (II).
The SRS indicator light comes on for about six seconds and goes off. Remove the SCS service connector from the MES connector (2P) within four seconds after the SRS indicator light went off.
The SRS indicator light comes on again. Reconnect the SCS service connector to the MES connector (2P) within the four seconds after the SRS indicator light comes on.
The SRS indicator light goes off. Remove the SCS service connector from the MES connector (2P) within four seconds .
The SRS indicator light indicates that the memory is erased by blinking two times.
Turn the ignition switch OFF , and wait for ten seconds.
i used the paper clipped method on the same way you check when he check engine light is on and its that little blue connector with the brown and black wire i used these instructions
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
also dunno if this helps but is a 94 civic dx stock d15b7 see the problem is with the tranny, the first 20-30 mins or so it shifts fine then locks into a false neutral and the only way to get it to grab again is to turn off and turn on the car then it works fine for about 1 min then have to repeat the process
Your transmission issue is a separate problem.
