Timing belt slipped b16a2
Old Jan 21, 2019 | 11:52 PM
Dlarsson112's Avatar
Default Timing belt slipped b16a2
My civic eg6 died a few days ago, just started the car and slipped with the foot and rev the enging to maybe 4000 by mistake and then it died, there was no specific sound of something crashing, After some research i found that de belt slipped on the intake cam, 4-5 teeth, do i have a total valve salad or does it made it, what do you guys think?
Old Jan 22, 2019 | 03:50 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: Timing belt slipped b16a2
It's a roll of the dice. I've seen just as many engines have valve to piston contact when the belt slips or breaks as those that didn't. Only way to check is to fix the belt and do a compression test.
Old Jan 22, 2019 | 03:51 AM
DumpdEJ6's Avatar
Also you should figure out why the belt slipped, they are designed not to do that so something is fucky with your engine.
Old Jan 22, 2019 | 04:38 AM
aw614's Avatar
10 Year Member
Loved
Put a new belt on and hope for the best. I had a timing belt cover bolt back out and shred half the belt on my GSR, slightly jumped timing and forced car to stall and not start. Put a belt back on and haven't had problems since.
WiedemannC
Dec 6, 2010 12:35 PM
MassCivicMan987
Jun 28, 2007 11:48 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
Imprezn
May 6, 2003 01:36 PM
