Is RSX wideband O2 capable for E85 supercharged?
Old Jan 19, 2019 | 05:24 PM
davidc's Avatar
Default Is RSX wideband O2 capable for E85 supercharged?
I'd like to know if the stock '04 RSX TypeS psuedo wideband 02 sensor is suitable for tuning a supercharged engine running E85? It was recommended to use the stock sensor since it is wideband and the ECU is a PRB K-series one, so...sort of plug and play.
I ask because I've read that AFR's for E85 should be down in the 9.5 range, and perhaps even a little richer if supercharged.
I've also read that the stock 02 sensor for the 04 RSX, while called wideband, only reads down to about 11.7.
Yet, I was told that it should be suitable.
What do you experienced guys think?
Car is a MY04 S2000 running Doctronic ECU (similar to KPro using '04 RSX TypeS)
Old Jan 21, 2019 | 06:48 PM
TypeC's Avatar
Default Re: Is RSX wideband O2 capable for E85 supercharged?
No, in my experience, the factory WB02 is fine near stoich, but below 12.x it is supper inaccurate (like a point plus off). I log factory WB02 and my Bosch 4.9. I'd never use the factory to tune.
$0.02
thewrai6th
Engine Management and Tuning
May 23, 2019 10:48 AM
SteelcityLude
Oct 9, 2011 11:56 PM
Realek4
May 18, 2005 02:10 PM
-KangaRod-
Jan 21, 2005 09:50 AM
-KangaRod-
Jan 19, 2005 08:16 AM
