how to unclip the wire harness 2000 accord
Old Jan 18, 2019 | 03:45 PM
davexnet's Avatar
Default how to unclip the wire harness 2000 accord
Hello -
I'm trying to get to the coolant temperature sensor, it's right below the distributor.
There is a plastic wire harness that's in the way, and I've been unable to
figure out how to pull it off of the bracket it's attached to.
Anybody know the secret ?
Thanks
Old Jan 19, 2019 | 05:04 AM
schreps's Avatar
Default Re: how to unclip the wire harness 2000 accord
If you look closely to where the black plastic harness looms attach to metal clip posts there are tabs that need to be pressed as you pull up on the loom. The hardness itself can be difficult to move because there's not a lot of slack. thats it.
Old Jan 20, 2019 | 12:12 PM
davexnet's Avatar
I still haven't figured it out. Here is an image of the harness in question. As can be seen, it's
attached on it's right hand side to the bracket. It seems as if it should slide to the back.
There is a single tab, but my manipulation of it (so far) have not yielded any positive results.
wire harness attached to bracket
Old Jan 20, 2019 | 04:59 PM
hondaslave1342's Avatar
Just take the bracket off with the wiring harness..
Old Jan 21, 2019 | 03:58 AM
schreps's Avatar
You may still not have enough room to get the sensor out without removing the distributor.
spoolinvtec54
Engine Management and Tuning
11
Feb 13, 2020 09:45 AM
Ken Lam
Jan 22, 2017 08:38 AM
mad_ox1
Jul 25, 2015 12:27 PM
