Hello, I am new to the Honda game so bear with me. I recently did a head gasket job on my d16y7. My head was warped so I got a head from the junk yard. Long story short I thought I'd finally completed the task however when I poured coolant in my radiator it began to leak it all out. I found the leak, is coming from the intake manifold. I also changed the intake manifold gasket with a felpro gasket. Are my bolts not on tight enough is the head bad? Did I not put the new intake gasket on correctly? Attached are some photos I don't know if they will help but there they are.
I had that same thought when I saw the copper crush washer sticking out from the manifold but I wasn't sure on the D16Y7 setup to be confident to post as such.
Yes, this ^^^^. The copper ringed opening should be around the coolant passage on the right (passenger) side of the cylinder head close to the distributor.
