Troubleshooting: No spark from 1.6 litre after initial startup
Old Jan 13, 2019 | 06:43 PM
gl89's Avatar
Default Troubleshooting: No spark from 1.6 litre after initial startup
Installed a time-sert into my buddy's 94 civic 1.6. Installed no issues and fired right up. Noticed an issue with a plug wire and pulled it out while running. Obviously engine misfired slightly but then completely died which I thought was odd. Wouldn't start back up . Found plugs to be fuel fouled and changed them. Checked for spark from wires and from coil and no spark now. Checked all fuses under hood and under dash-all good . Didn't have my voltmeter so couldn't test for power to the distributor. Is it possible the ICM crapped out when I pulled the plug wire? What else should I test?
Old Jan 14, 2019 | 09:05 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default re: Troubleshooting: No spark from 1.6 litre after initial startup
You probably blew the coil by pulling the wire while it was running.
Old Jan 15, 2019 | 03:03 AM
NVturbo's Avatar
O.G. triple O.G.
you should stop "ATTEMPTING" to work on cars.
Old Jan 17, 2019 | 08:57 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: Troubleshooting: No spark from 1.6 litre after initial startup
Basically if you have 12v+ to the black wire with yellow stripe on the dizzy plug with ignition on and the cam is turning the distributor and no spark it's more then likely a bad coil. You can do a resistance test on the coil terminals to determine that it failed. These parts are just getting super old and aftermarket coils fail just as often as old parts. If you wanna play it safe just replace the whole distributor with a known working dizzy and it should fire right up.
gl89
Jan 15, 2019 12:03 PM
jakescakesz06
Jan 4, 2016 09:38 AM
vtec.dc2
Jan 20, 2006 04:49 PM
