No spark - Honda-Tech - Honda Forum Discussion
No spark
Old 01-13-2019, 07:46 PM
Default No spark
Installed a time-sert into my buddy's 94 civic 1.6. Installed no issues and fired right up. Noticed an issue with a plug wire and pulled it out while running. Obviously engine misfired slightly but then completely died which I thought was odd. Wouldn't start back up . Found plugs to be fuel fouled and changed them. Checked for spark from wires and from coil and no spark now. Checked all fuses under hood and under dash-all good . Didn't have my voltmeter so couldn't test for power to the distributor. Is it possible the ICM crapped out when I pulled the plug wire? What else should I test?
gl89 is offline
Old 01-13-2019, 08:27 PM
Freedo_Civegra's Avatar
Default Re: No spark
Probably that ICM took a crap. WELCOME TO BROWN TOWN, BOYYYYY.
Freedo_Civegra is offline
Old 01-14-2019, 02:01 AM
Stancetard Hate Monger
eghatch9295's Avatar
likely you killed the coil
eghatch9295 is online now
Old 01-15-2019, 12:31 PM
talks to himself
CX-Adam's Avatar
I, literally, just did this less than two weeks ago. Same issue. The problem was the coil.
CX-Adam is offline
Old 01-15-2019, 01:03 PM
tony_2018's Avatar
I learned from this post, never to pull a spark plug wire while running.
tony_2018 is offline
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
