Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Ignition switch vs lock cylinder
Old Jan 4, 2019 | 12:19 PM
fazalabbas's Avatar
Default Ignition switch vs lock cylinder
My 1999 Odyssey has all the symptoms of failing ignition switch. Now there are two options I can go with. Replacing just the ignition switch or replacing ignition switch with lock cylinder.
Following are the reference what I am talking about.
Option one is
Amazon Amazon
Option two is
Amazon Amazon
How do I know that my issue is the relay or my issue is the cylinder lock?
My van symptoms are
Car stalls while driving
Car starts and then suddenly stalls
Issues powering on the accessories. Sometimes it takes few seconds for accessories to lit up after first turn of key
Thanks
Abbas
Old Jan 4, 2019 | 03:04 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Ignition switch vs lock cylinder
The issue is usually due to the ignition switch (electrical switch).
https://f01.justanswer.com/clmcr8/0d...30_A02-031.PDF
Old Jan 5, 2019 | 10:36 PM
fazalabbas's Avatar
Thanks for the information. I'll call dealer to check if they can do anything with recall for free :-)
I'll go with ignition switch to start with now. If that dont solve then will buy the key cylinder also.
Thanks
JohnnyEF
May 10, 2009 04:10 PM
romerosi
Feb 26, 2009 04:35 PM
benmyfriend
Dec 4, 2005 09:54 PM
