Ignition switch vs lock cylinder
My 1999 Odyssey has all the symptoms of failing ignition switch. Now there are two options I can go with. Replacing just the ignition switch or replacing ignition switch with lock cylinder.
Following are the reference what I am talking about. Option one is Option two is How do I know that my issue is the relay or my issue is the cylinder lock? My van symptoms are Car stalls while drivingThanks |
Re: Ignition switch vs lock cylinder
The issue is usually due to the ignition switch (electrical switch).
https://f01.justanswer.com/clmcr8/0d...30_A02-031.PDF |
Originally Posted by tech8
(Post 51822481)
https://f01.justanswer.com/clmcr8/0d...30_A02-031.PDF I'll go with ignition switch to start with now. If that dont solve then will buy the key cylinder also. Thanks |
