Anyone Pressed Bushings Before?
Old Dec 13, 2018 | 07:35 PM
Jon Petersen's Avatar
Default Anyone Pressed Bushings Before?
1995 Civic EX coupe. I've had some rear suspension noises for the past forever. I replaced the trailing arm bushings and upper arms on both sides, which improved the handling a lot, but the clunking hasn't stopped. I pressed the trailing arm bushings without removing the trailing arms from the car, and I don't know that that's possible doing other bushings. There's a constant rattling on the rear driver side, and there's a slamming on the rear passenger side when the suspension bottoms out (like, going over speed bumps). I did some prying around, and it appears that at least 2 of the 3 lower arm bushings are shot, though I can't remember which 2. (In the attached diagram, they're bushings 19, 19, and 24 on each side.) I bought one bushing 19 and one bushing 24 for each side, as well as bolts.
I wanted to know if any of you have pressed bushings before and could give me any advice. Thanks.
There are two 19 bushings. Just fyi.
Old Dec 14, 2018 | 06:52 AM
Kevs02Accord's Avatar
Default Re: Anyone Pressed Bushings Before?
Using what, a hydraulic press or something else?
Old Dec 14, 2018 | 10:25 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Good luck!
I have noises as well, I am curious what my coil over units look like. It would almost be worth it to pull them and see if they could be the source of the noise...
Old Dec 14, 2018 | 10:30 AM
tony_2018's Avatar
Fish Twig
inspect the bushing to ensure it is bad, grease the area where the bolt makes contact with the bushing.
Old Dec 14, 2018 | 04:04 PM
Premium Member
Loved
Community Favorite
When I looked at those bushings, it was cheaper to buy a new LCA - complete w/ new bushings...
Old Dec 18, 2018 | 07:36 PM
I was just going to rent a mechanical press from NAPA or something.
I've pried around, and there's a lot more play than I feel is healthy for the car. Is that what you mean?
Old Dec 18, 2018 | 07:37 PM
Well that sucks. Already got 4 of the bushings and bolts. Oh well.
Old Dec 18, 2018 | 09:56 PM
Chrisfrom1986's Avatar
Go to a machine shop and hand them 6 new bushings and the lcas.
Old Dec 19, 2018 | 06:12 AM
BiggieBert's Avatar
Loved
Community Favorite
I’ve done bushings with the master ball joint removal set from Auto Zone. Really quite easy.
Jon Petersen
10
Mar 31, 2019 05:01 PM
Rob.
11
Jul 8, 2012 07:13 PM
SE7EN3S
Suspension & Brakes
Sep 16, 2005 09:41 AM
Jays91DXhatch
Apr 27, 2005 08:19 PM
Jdm93civic
Aug 15, 2003 05:35 AM
