Anyone Pressed Bushings Before?
1995 Civic EX coupe. I've had some rear suspension noises for the past forever. I replaced the trailing arm bushings and upper arms on both sides, which improved the handling a lot, but the clunking hasn't stopped. I pressed the trailing arm bushings without removing the trailing arms from the car, and I don't know that that's possible doing other bushings. There's a constant rattling on the rear driver side, and there's a slamming on the rear passenger side when the suspension bottoms out (like, going over speed bumps). I did some prying around, and it appears that at least 2 of the 3 lower arm bushings are shot, though I can't remember which 2. (In the attached diagram, they're bushings 19, 19, and 24 on each side.) I bought one bushing 19 and one bushing 24 for each side, as well as bolts.
I wanted to know if any of you have pressed bushings before and could give me any advice. Thanks.
There are two 19 bushings. Just fyi.
Premium Member
Re: Anyone Pressed Bushings Before?
Good luck!
I have noises as well, I am curious what my coil over units look like. It would almost be worth it to pull them and see if they could be the source of the noise...
Jon Petersen
10
03-31-2019 05:01 PM
Rob.
11
07-08-2012 07:13 PM
