Help with D16A6 Camshaft
Old Dec 10, 2018 | 09:32 AM
kraquepype's Avatar
10 Year Member
Default Help with D16A6 Camshaft
Cross posting here, some of you may have experience with this cam. Originally posted in engine / machining tech forum.
I purchased an Exospeed SR909 camshaft from another member a few weeks back. Got around to installing it today, and was having a hard time telling the difference between the cam I received and my stock unit.
Can someone familiar with the Exospeed cams tell me if the cam I received is correct? Side by side I'm having a hard time telling the difference.
I did go ahead and install it anyway, its running OK but I can't tell much of a difference right now.
Below are some images of the 2 cams, the Exospeed cam is on the right, stock on the left.
Old Dec 10, 2018 | 02:40 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Help with D16A6 Camshaft
they 'look' the same to me as well.
Regrinds that add lift have material removed on the large base circle/heel end (opposite of the lobe/nose).
To know for 100%, you should measure the lobes and see if they have the same profile.
Old Dec 11, 2018 | 04:46 AM
kraquepype's Avatar
10 Year Member
Thanks... looking at the lobes closest to a bearing surface I can't see a difference, but you are right about measuring. I'd need to get a caliper gauge to be sure.
Are performance cams typically this close, visually? I don't have any past experience with D16 cams.
Old Dec 24, 2018 | 07:34 AM
kraquepype's Avatar
10 Year Member
I found an old listing for a SR909 cam, there does appear to be less material on the lobes if you look at the ones close to the cam journals.
https://honda-tech.com/forums/sale-1...d-new-1842501/
In my pictures there appears to be more material in those areas of the lobes.
Old Dec 24, 2018 | 08:14 AM
muellersfan's Avatar
Originally Posted by kraquepype
I'd need to get a micrometer to be sure.
Fixed
kraquepype
Engine Machining & Assembly
Dec 8, 2018 03:38 PM
speedysohc
Jun 28, 2006 08:59 AM
FIST321
May 3, 2006 12:06 AM
blkwidow420
Apr 14, 2005 01:37 AM
