Shopping for a new aftermarket distributor for 93 Civic VX
OEM distributors for the VX are discontinued so I have to buy aftermarket. There are a lot on different parts websites but most of them have little to no reviews. Anyone here have experience with aftermarket distributors?
If you have the old Honda VX distributor, then rebuild it.
I'd rather just get a new dizzy. Are there any good guides on how to rebuild? I could do it if it's not too hard. Also what would be the price difference between rebuild and buying new?
Yes they are the same. (VTEC distributor)
if you have the tools to work with the bearing and seal, the rest is very easy to do.
price difference: less than half.
The bearing is the easy part. I don't have it handy, but it's made by Nachi and I have bought them before. It's the seal that's more challenging to find.
The distributor oil seal is available from local auto parts stores, and also on Amazon...
https://www.amazon.com/APDTY-Distrib...butor+oil+seal
I believe so. To verify on Amazon, entire year, make, model, and trim of Honda car for which the distributor was originally designed.
Edit: I just verified that the distributor seal also fits the B16a2 distributor on the 2000 Civic Si.
Also available on eBay
https://www.ebay.com/sch/i.html?_fro...1-732&_sacat=0
Brand New Distributor Reseal Kit
Allows you to reseal your distributor to keep out oil that will eventually cause the distributor to fail.
Fits 1997-1999 Acura CL
Fits 1976-2002 Honda Accord
Fits 1997-2000 Honda CR-V
Fits 1988-1991 Honda CRX
Fits 1975-2000 Honda Civic
Fits 1993-1997 Honda Civic Del Sol
Fits 1979-2001 Honda Prelude
Fits 1984-1987 Honda Wagovan
Replaces 30110-PA1-732, 30110PA1732
Looks like the bearing is here:
6001/012.45 2RS bearing - Bearing Depot & Supply
Sealed radial ball bearing with 12.45mm bore X 28mm x 8mm wide. Used on Honda and Acura distributors.
$19.50
$19.50
$19.50
$19.50
94eg8 mentioned a nachi bearing so gonna try to find that one, I think the bearing in the link is correct, just not sure which brand, I try to avoid the Chinese bearings
FBJ Bearings for Industrial Sector
FBJ has produced many standard and specialised types of ball and roller bearings under Japan Industrial Standard (JIS) and International Standardlization Organisation (ISO).
It looks like they have been an OEM supplier for a few industries.
