Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   Shopping for a new aftermarket distributor for 93 Civic VX (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/shopping-new-aftermarket-distributor-93-civic-vx-3331197/)
crz650 12-06-2018 05:13 PM
OEM distributors for the VX are discontinued so I have to buy aftermarket. There are a lot on different parts websites but most of them have little to no reviews. Anyone here have experience with aftermarket distributors?
muellersfan 12-06-2018 06:05 PM
Re: Shopping for a new aftermarket distributor for 93 Civic VX
If you have the old Honda VX distributor, then rebuild it.
eghatch9295 12-06-2018 06:36 PM
iirc, the z6 is the same distributor.
crz650 12-06-2018 07:26 PM
How can I tell if I have the original distributor? I'm pretty sure it's been replaced.
muellersfan 12-06-2018 07:28 PM
Multi-angle pics would help.
Based on eghatch's comments, you can use a z6 distributor internals to rebuild it, if it's the original.
eghatch9295 12-06-2018 08:45 PM
ear pattern is the same also
muellersfan 12-06-2018 08:48 PM
Easier yet!
eghatch9295 12-06-2018 10:11 PM
to my knowledge, the only 92-00 d series with a truly unique distributor is the d16y5.
crz650 12-07-2018 09:06 AM
I'd rather just get a new dizzy. Are there any good guides on how to rebuild? I could do it if it's not too hard. Also what would be the price difference between rebuild and buying new?
Relic1 12-07-2018 10:57 AM
Yes they are the same. (VTEC distributor)
if you have the tools to work with the bearing and seal, the rest is very easy to do.
price difference: less than half.
triple beam 12-07-2018 10:57 PM
i bought brand new distributor at Oreillys and it works great.. i think i paid 160 dollars
muellersfan 12-08-2018 05:57 AM
Honda distributors are far more superior with respect to function and reliability.
eghatch9295 12-08-2018 08:41 AM
parts store distributors are hot garbage. i'd rather have used oem.
TomCat39 12-08-2018 09:48 AM
If I might inquire, what tools are required for the bearing and seal if you are rebuilding these things?
94 Civic Si 12-08-2018 12:54 PM
I am guessing at least a seal puller, but I thought the replacement bearings were unknown p/n's...
94EG8 12-09-2018 05:06 AM
The bearing is the easy part. I don't have it handy, but it's made by Nachi and I have bought them before. It's the seal that's more challenging to find.
muellersfan 12-09-2018 05:48 AM
The distributor oil seal is available from local auto parts stores, and also on Amazon...
egsleepercivic 12-10-2018 07:44 PM
Does it happen to be the same bearing for a b series, specifically a b16a distributor, if so can you share the part #
https://www.amazon.com/APDTY-Distrib...butor+oil+seal
same thing, is this the same seal for b series distributors
muellersfan 12-10-2018 07:54 PM
I believe so. To verify on Amazon, entire year, make, model, and trim of Honda car for which the distributor was originally designed.
Edit: I just verified that the distributor seal also fits the B16a2 distributor on the 2000 Civic Si.
Brand New Distributor Reseal Kit
Allows you to reseal your distributor to keep out oil that will eventually cause the distributor to fail.
Fits 1997-1999 Acura CL
Fits 1976-2002 Honda Accord
Fits 1997-2000 Honda CR-V
Fits 1988-1991 Honda CRX
Fits 1975-2000 Honda Civic
Fits 1993-1997 Honda Civic Del Sol
Fits 1979-2001 Honda Prelude
Fits 1984-1987 Honda Wagovan
Replaces 30110-PA1-732, 30110PA1732
Also available on eBay
https://www.ebay.com/sch/i.html?_fro...1-732&_sacat=0
94 Civic Si 12-11-2018 09:09 AM
Anyone tried these guys?
https://www.aipelectronics.com/index...vic-475818&p=1
94 Civic Si 12-11-2018 09:24 AM
Looks like the bearing is here:
6001/012.45 2RS bearing - Bearing Depot & Supply
Sealed radial ball bearing with 12.45mm bore X 28mm x 8mm wide. Used on Honda and Acura distributors.
$19.50
egsleepercivic 12-11-2018 11:58 AM
$19.50
Thanks for the links and info
94eg8 mentioned a nachi bearing so gonna try to find that one, I think the bearing in the link is correct, just not sure which brand, I try to avoid the Chinese bearings
egsleepercivic 12-11-2018 12:12 PM
think this may be the nachi ones
20 pack lol
94 Civic Si 12-11-2018 12:35 PM
https://www.amazon.com/6001-2NSE9-be...+nachi+bearing
20 pack lol
20 bearings for $10?!?
TomCat39 12-11-2018 03:10 PM
It appears FBJ Bearings are a quality product.
FBJ Bearings for Industrial Sector
FBJ has produced many standard and specialised types of ball and roller bearings under Japan Industrial Standard (JIS) and International Standardlization Organisation (ISO).
It looks like they have been an OEM supplier for a few industries.
