Lil Gnome's New Suggestion Parts list thread B18C1 turbo
Old May 21, 2013 | 04:48 AM
the_insider's Avatar
Default Lil Gnome's New Suggestion Parts list thread B18C1 turbo
Hey guys,
So i am now looking to buy parts for my engine to do the conversion.
I am keeping the stock bottom end, and looking to see if I have missed any parts off my list.
Not buying a kit as some parts i have from previous cars and others i can get on the cheap.
Td05 turbo charger from an evo
Turbo manifold
Pipe work and intercooler
Oil catch tank with pipe work
T-peice for oil pressure switch with pipe work to turbo
New inlet manifold, skunk2/blox/ect
Injectors. Will 440cc be enough and will/should i need fuel rail?
Fuel pump
Down pipe
Ecu, i believe p78 with chrome will be ok with base map to allow me to get it mapped on RR?
Is there anything i have missed off the list or suggest i add on?
Thanks in advance
James
Old May 21, 2013 | 04:53 AM
grumblemarc's Avatar
The Grumpiest
Default re: The Insider's B18C1 Build parts suggestion thread
Oil drain lines
Tapped oil pan
A real EMS. A basemap on CROME doesn't cut it.
Gauges to monitor air/fuel. oil pressure.
Downpipe
A horsepower goal
What kind of 440 injectors? Will they require a resistor box.
Read the link in my signature.
Old May 21, 2013 | 05:02 AM
Nice one, gauges i do have on my ebay watch, forgot to add to list. And downpipe is on.
With regards to injectors, i have read about resistor box, but if im honest i would rather not have injctors that need that.
Which do you recomend, it dowsnt have to be 440, i jusy read a few people running them.
Bhp figure, i dunno, would like to get 350, but a solid safe 300 would be nice.
Thanks for the link, will take a look now
Originally Posted by grumblemarc
Oil drain lines
Tapped oil pan
Downpipe
A horsepower goal
Old May 21, 2013 | 05:19 AM
th3pwn3r's Avatar
Suggestions:
Heat management
Brake replacement/upgrades
Suspension upgrades
Old May 21, 2013 | 06:07 AM
The Grumpiest
Ditto this^^^
I upgraded brakes, suspension, cooling and exhaust before I bother with Forced Induction.
Old May 21, 2013 | 06:57 AM
Schister66's Avatar
Man U FTW
If you're looking for 350whp, those 440cc injectors are going to be too small.
Also, you're making things complicated by not using a standard T3 framed turbo. You might be able to find a manifold for that Evo 16g, but it will be more difficult to find and more expensive than a standard manifold.
For parts, I would avoid eBay...check the marketplace: www.hondamarketplace.com
Old Nov 27, 2018 | 10:35 PM
Lil Gnome's Avatar
Is it weird to bring this back up? I wanted to know if anyone could provide a list of recommend parts for a turbo build.
Goal: 400whp (reliable)
Budget: I have a 'decent' income
Power Plant: B16A (it from a CRX SiR)
Chassis: EK Sedan
I am curious about if I need to do anything to the bottom end. New pistons, connecting rods, etc. Any info you could provide, thank you.
Old Nov 27, 2018 | 11:41 PM
extremeracer's Avatar
Chassis: EK Sedan
There are a few threads going at the moment with similar questions and goals as yours...so be sure to check them out.
  • 400whp is beyond the safe scope of standard internals and especially a B16 due to the smaller capacity.
  • You will need Rods & Pistons as a minimum (Wiseco/Manley/CP shelf pistons and Eagle/Manley/BC H-beam rods)
  • I'd also do a CSS block for safety and ARP headstuds.
  • BC/Manley/Supertech Valvesprings & Retainers
  • Stock cams are fine however GSR/CTR/ITR cams will make more power
  • Get a Go-Autoworks turbo kit (any variant except the long-runner top mount) with a turbo that's rated at 450 - 500hp (52 - 57mm)
  • Decide what fuel you going to run on (93 or E85)
  • 1000cc injectors
  • 255/340 lph fuel pump depending on whether 93 or E85
  • Adjustable Fuel pressure Regulator
  • Stage 4 clutch
  • Hondata/Neptune
Old Nov 28, 2018 | 01:21 AM
Balor_Gr's Avatar
^ Thats a good answer.
Thats out of subject but dam i wan to visit africa some time.
Old Nov 28, 2018 | 05:52 PM
Lil Gnome's Avatar
  • 1000cc injectors
  • Stage 4 clutch
  • Hondata/Neptune
I really appreciate you. Thank you.
Old Nov 29, 2018 | 09:38 AM
TheShodan's Avatar
Moderator
Lil Gnome inadvertently received some good information from some valued members after ThreadJacking an old thread. This is the attempt to keep the information within the thread intact and put the old one to bed.
So, yes, Lil Gnome, this is weird. Please don't do that again. Just create your own thread with your own topic, to avoid confusion.
Old Nov 29, 2018 | 07:30 PM
Lil Gnome's Avatar
Default Re: Lil Gnome's New Suggestion Parts list thread B18C1 turbo
Ok. It was not an attempt at anything but what I asked. It will not happen again.
jdm-boy
Aug 19, 2012 01:23 PM
ccssk8ter11
Feb 28, 2008 12:38 PM
fin781
Oct 27, 2007 09:28 AM
firstgenrex
Nov 19, 2003 06:44 AM
