B20 —> EG
Old Nov 21, 2018 | 03:01 PM
K-G's Avatar
K-G
Default B20 —> EG
Hey all I’m almost done with my b20 build. However I have come across something that I read, I will have to change my timing belt side post mount because it will sit uneven in my bay? (The motor currently has the 2 bolt post mount)
The motor will be going into a 93 civic ex.
I was not aware of this if this is true.
I just assumed I could use my OE civic driver side mount since they were the same bolt pattern. Never would of thought it would not sit level.
Confused on this mount thing
Old Nov 21, 2018 | 08:13 PM
tony_2018's Avatar
Fish Twig
Default Re: B20 —> EG
ok, so does it sit crooked?
Old Nov 21, 2018 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, the CRV engine bracket on the left side will cause the timing belt end of the engine to sit LOWER than normal, so the engine will NOT sit level in the engine bay. Switching to either a '99-00 Civic Si engine bracket (if you intend to use a two-bolt mount) or a '94-01 Integra bracket (if you intend to use a three-bolt mount) will cure your problem.
Factory OE Bracket part numbers: '00 Civic Si = 11910-P30-000 and the Integra bracket = 11910-P72-000
Old Nov 22, 2018 | 01:37 AM
K-G's Avatar
K-G
hey thank you for the reply ! This has saved me a lot. I would of ended up pulling my motor and been screwed. Thankfully I enjoy to read a lot on here. The forum I was mainly using didn’t mention nothing about changing the post mount. I will be adding that to the list of parts.
Old Nov 22, 2018 | 02:10 AM
K-G's Avatar
K-G
Would I be able to use the post mount off my single cam ? Z6?
Old Nov 22, 2018 | 04:03 AM
tony_2018's Avatar
Fish Twig
do the bolts line up?
Old Nov 22, 2018 | 06:35 AM
K-G's Avatar
K-G
I checked majestic Honda. The item numbers are different so to answer my own question or if anyone else was wondering, no it won’t work.
Old Nov 22, 2018 | 05:41 PM
egsleepercivic's Avatar
b20 drivers side engine side part of the mount is different, when I put a b20 in my 94 LS i used the original ls engine mount the b20 is different\longer
Old Nov 22, 2018 | 07:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Unfortunately, to swap the bracket properly, it is easiest to pull the engine out if you haven't already essentially completely installed it. One of the three bolts holding the bracket to the block is covered by the lower timing belt cover and thus needs to be removed to access it. This means that the crank pulley must come off in order to remove that lower timing belt cover.
Old Nov 23, 2018 | 08:37 AM
K-G's Avatar
K-G
Luckily it’s my winter build so she’s still on the engine stand. Just picked up a competition clutch 12lb flywheel for her today. Excited for spring
Old Nov 23, 2018 | 08:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Well... the bracket will be easy-peasy to swap then. Good luck OP. Enjoy.
miamihonda
Mar 27, 2021 05:10 AM
Recyclingfreak
May 6, 2017 08:27 PM
b20ek
Jun 28, 2003 12:40 PM
Civic Racer
Apr 2, 2003 11:20 AM
