Air Refiner
Very cool, didnt know they existed. Looks to be a JDM part and not USDM, if this is the case the wiring harness wont have a plug for it. It probably needs 12 volts but the question is how many amps? If you have a dvm that measures current put it inline and connect to the battery to determine the amps. Then wire to the fuse box, maybe on the accessory, blower or rear window defrost circuit, and the right size inline fuse after you measure the current.
After a little googling, there is a remote or controller that may be needed... you should contact one of the big JDM parts guys for the skinny.
https://www.preludepower.com/forums/...d.php?t=330462
This guy had the harness, maybe the JDM folks can get you one.
https://www.clubcivic.com/forum/thre...ner-pa.172617/
JDM*addiction
Mar 31, 2007 06:07 PM
Draggin99Si
19
Mar 23, 2005 10:45 PM
