Non vtec civic engine light flashing code 22
Old Oct 29, 2018 | 08:48 AM
Savvababi's Avatar
Default Non vtec civic engine light flashing code 22
My check engine light came on and its flashing code 22 (22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch) I have a 98 civic ex automatic non vtec. Everything stock! Why does this code keep coming up?
Old Oct 29, 2018 | 09:08 AM
muellersfan's Avatar
Default Re: Non vtec civic engine light flashing code 22
Wrong ECU for the engine in your car
Old Oct 29, 2018 | 09:14 AM
Savvababi's Avatar
I checked that...it is the original ECU..p2p for automatic
Old Oct 29, 2018 | 09:17 AM
Ummm... this means that the non-vtec engine does not match with the original VTEC ECU. Buy the correct ECU for your engine and wire harness.
P2P is for the D16Y8 VTEC engine.
Old Oct 29, 2018 | 09:29 AM
Savvababi's Avatar
37820-p2p-a84
Old Oct 29, 2018 | 09:33 AM
37820-p2p-a84
This VTEC engine ECU will throw VTEC codes when used with a non-VTEC engine (D16Y7?).
Old Oct 29, 2018 | 09:37 AM
Savvababi's Avatar
Y16R8
Old Oct 29, 2018 | 09:39 AM
Y16R8
Did you mean D16Y8, which is a VTEC engine? If so, why does your original post state that the car has a non-VTEC engine?
Post pics of your engine bay.
Old Oct 29, 2018 | 10:04 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Googling Y16R8 provides links to 2016 Alvolante in Italy.
You have posted in the wrong section for your vehicle. Also, I am not sure what section is appropriate so at this time, thread closed.
mostafafarran
May 5, 2018 08:10 AM
Dahhhbeed
14
Aug 27, 2016 03:08 PM
morglum
Honda CR-V & Element
Mar 25, 2015 01:57 PM
EF-ingB16
Nov 4, 2011 05:40 PM
just_a_sohc
Dec 27, 2001 08:52 AM
