Alternator/Sp sensor Fuse keeps blowing
I’ve check grounds , Wiring , New battery, New alternator, Good speed sensor. Ill replace the Fuse and take it around the block after like 2 pulls once it gets higher in the rpms The Fuse blows and my speedometer stops working. I have not check the grounds with a multimeter yet
Definitely check for shorted wires under the intake manifold bracket. If that's not the problem, then check for a shorted O2 sensor heater wire. They are another common cause for fuse 15 blowing.
RedneckRicer
20
Apr 9, 2014 08:19 PM
SkIp_Civic_Ek6
Oct 31, 2006 08:53 PM
