New Honda owner need some help about my engine
Old Oct 16, 2018 | 03:52 PM
PennyPincher's Avatar
Default New Honda owner need some help about my engine
So just recently bought a 97 hatch civic. On the block I found D16Y8. My oem cat/headers are cracked and welded but I need a new one. So I went part hunting on Facebook,OfferUp and craigslist. Make story short I found a header (not oem) then the guy looked at my engine and told me I have a y8(vtec)bottom and a y7 top. 1st question is why would somebody do that? 2nd should I look for a y8 or y7 oem header/cats 3rd where can I find a guide that tell me what year and car model I can pull parts from? Thank for the help in advance IM SO LOST PLEASE HELP
Old Oct 17, 2018 | 04:57 AM
hondamark35's Avatar
Default Re: New Honda owner need some help about my engine
DX hatch?
1) the blocks are interchangeable. if the original Y7 was damaged (spun a bearing- which they seem prone to doing, had low compression, tossed a rod..ect) and a Y8 block was readily available or cheap, the easiest thing to do to fix the engine is just swap the bottom end and keep everything else original. a complete Y8 swap would require more work (and parts which cost money...)
2) any exhaust manifold/header for '88-'00 model year civic with a single cam (D-series) will bolt up to your engine. however, you're cat. converter is built into the manifold. generally, if you get anything other than stock replacement (D16Y7, '96-'00 DX, LX) you will need to have a cat. added under the car to pass emissions. i can confirm that a factory Y8 manifold will mate up to the rest of the exhaust without a cat... but it stinks, literally.
I'm sure there are plenty of guides around with even more info. try a google search with "site:honda-tech.com/forums" at the end for the best results.
Old Oct 17, 2018 | 12:23 PM
It’s suppose to be a DX. How much am I looking at for a complete y8? And would it manttwr if the part came from an auto trans or not?
Old Oct 17, 2018 | 12:27 PM
I mean would it matter if the oem headers came from auto trans ?
Old Oct 17, 2018 | 01:30 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
As far as I know the 6th gen isn't too different from the 5th gen and neither the intake manifold or the exhaust manifold are transmission specific. The area that can be transmission specific would likely be in the throttle body, but I'm not sure that applies to the 6th gen like it does the 5th gen.
Old Oct 17, 2018 | 05:25 PM
Depends in part on where it's coming from. I've been given motors for free before, bought from Craigslist for $300 as a decent running engine (still did some maintenance before install) pulled junkyard motors for $120 and put $300 in parts for reliability rebuild. Check the regional classified section here for what guys are asking too.
Exhaust manifold is same no matter the transmission. IACV on auto equipped Y8 intake manifold is 3-wire, throttle body mounted like the Y7. Not compatible with manual, Y8 conversion. If you buy a complete Y8 swap, you'll need it to be from a manual
Old Oct 18, 2018 | 08:10 AM
Ok thanks a lot. I have a guy with d15y8 can I use his oem header/cats and his y8 top?
graham412
Apr 12, 2010 03:37 PM
Tronski
20
Jan 25, 2009 07:35 AM
roycivic92
Dec 4, 2007 11:00 PM
EK45VTi
Aug 7, 2006 08:42 AM
AgentJam
11
Nov 7, 2003 02:05 AM
