'99 CX Auto - jerky under light throttle
I've got a 99 auto CX hatch (D16Y7). It's my winter car, so it's been sitting for the pat 6 months or so. Basically if I apply the throttle very lightly, the car is really jerky - like the throttle gets flipped on then back off again every second. Anyone know a fix for this? Thanks.
It's while driving. If I hold the throttle lightly in one specific spot, it does this. Like if I'm driving in a parking lot or in a place where I'll be driving slowly for a not so short distance but at low speeds. Not a huge problem, just really annoying.
You both can do a resistance check on the throttle position sensor. Make sure you see a smooth transition in resistance across the entire range.
Are all of your other tuneup items in order? I've had Civics in the past have funky misfiring issues and it was usually ignition components in poor condition. Has the ATF been serviced recently?
^ this could be fuel/ignition/vacuum related. The tps is a very tough part, and unlikely to be bad, But it’s easy to check with voltmeter. I think you want to see 4.5-5v at wot, someone correct me if I’m wrong. You can also try checking/swapping your spark plugs and wires as well as looking inside your distributor for corrosion. Check your iacv for gunk. There is an engine coolant temperature sensor that sits under the distributor that is crucial for part throttle operation. You can unplug it to see if your condition goes away. This will cause a check engine light to come on. Also your o2 sensor could be going bad. I’m sure there’s more possibilities.....
I've swapped my o2 sensor already so I don't think that's it. The only code I have is for an evap leak. This also doesn't happen all the time. It didn't start until I started driving the car again about a month ago, and I wasn't able to make it happen on my drive home today. I'm very certain it's not a misfire as it's not sputtering or backfiring when it happens, it's literally a very even pattern, maybe half a second with power then half a second without, and back and forth until I let my foot off the pedal or give it more throttle.
Chances are I'm not going to do anything about it unless it's a sign of impending doom as this is just my winter beater, but I do appreciate the suggestions.
OP, does your issue occur at all times--warm or cold, or is there a specific rhyme or reason to it?
A failing TPS can break up specific throttle positions. Fuel trims based on the oxygen sensor outputs don't usually come into play until the car is warmed up when it enters closed loop operation.
You still have not mentioned any maintenance history. What's going on in that regard? What have you replaced recently?
The evap system leak may also spell issues. What code(s) is your car throwing off?
I'll take a look at the IACV this weekend. I have no idea about air in my cooling system, though I did have trouble with my car overheating last summer (the radiator motor was seized). How would I go about flushing any air out? I suppose I can just google it.
radiator motor? What is that? Anywho, yeah there’s a couple different ways to go about it. I’m going to assume that if you exposed your cooling system to air by removing any coolant hoses during the summer and you don’t know how to do a bleeding procedure, then you have air in your cooling system. This can wreak havoc on your motor.....
As for my issue, I haven't tried to duplicate the issue when the engine is cold, I will try that. I have no codes.
Maintenance;
new IACV
new plugs, wires, cap and rotor
new valve cover gasket (was leaking into spark plugs)
new fuel pump and filter
bleed the coolant system for 45+ min
I need to get some tranny juice and do an exchange. As well as check the TPS it seems.
Edit, its possible that after I swapped the fuel pump / filter it was better for a day or 2, although not 100% sure about that.
Maintenance;
new IACV
I do not know if this is the case, but I did notice that my 96' civic would be quite jerky at low speeds, almost like I did not know how to drive a manual (mine is 5-speed), but it went away once I used 89 octane gas. Maybe that is not what was causing it, but if the octane is too low, it would cause pre-detonation which I believe makes logical sense as too why my car was jerky under small load. The car would also almost stall at stop lights because the idle would be around 700-750 then drop to about 200-300 RPM. Ever since I used the 89 octane gas, this issue has gone away. This was recent, I will let you know if my problem persists.
Diversion
15
Oct 14, 2009 10:25 AM
silentblackhat
Apr 7, 2005 10:12 PM
