93Eg sunroof slide problem *searched*
Old Sep 26, 2018 | 06:53 AM
cisco_kid's Avatar
Default 93Eg sunroof slide problem *searched*
What's up guys.. I did not find the answer to this so here it goes.
Car is a 93EG Si.
First off, everything on my sunroof was working fine. It tilts up and it also slides back fully to open.
Now it does tilt up but it only slides back to open about 2 inches and then stops. It does not want to fully open(slide back). So it starts to slide back and then it gets stuck.
Old Sep 26, 2018 | 07:30 AM
cisco_kid's Avatar
Default Re: 93Eg sunroof slide problem *searched*
Upon inspecting the rails I found a wire piece that looks like a spring and it is loose.(see pictures).
do I have to pull down the headliner to install this?
Old Sep 26, 2018 | 08:03 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Most likely. :/ Unless you can see where it goes and can get your fingers in there....
Old Sep 26, 2018 | 10:27 AM
Relic1's Avatar
It's been many years since I was in there but I don't think you have to pull the headliner.... just remove the glass.
You can then 'help' the mech move around to get access to it.
You will likely have to realign the mech to get everything working perfectly again though.
*edit* the question is.... why did it come off?
Egchico69
Jan 24, 2013 09:38 PM
92ehatch
Audio / Security / Video
Nov 26, 2005 10:19 AM
wish_i_was_h22a
Nov 14, 2005 06:57 PM
Jonathan_ED3
Welding / Fabrication
13
Sep 27, 2005 07:12 PM
B20poweredDA
Dec 2, 2004 09:57 PM
