Infinity sub / repair
Old Nov 26, 2005 | 08:53 AM
92ehatch's Avatar
Default Infinity sub / repair
ok my sub quit working, but when i push down the positive wire going from the terminals to the voice coil it starts working again, kinda like there is a loose connection there.
is there any way to repair that? or is it fukt
Old Nov 26, 2005 | 09:16 AM
92ehatch's Avatar
Default Re: Infinity sub / repair (93egsedan)
i took a piece of spair wire and kinda wrapped it around the one on the sub, put a 9v batt on it and it makes sound, so its fixable it looks like, now i just need to find a way to get it on there permanently
any other ideas still appreicated
Old Nov 26, 2005 | 09:22 AM
fcm's Avatar
fcm
Old Fart
If the connection problem is at the term. it's not that hard, heat up the solder and pull the tinsel wire through a little bit more and re solder, however if the problem is at the connection on the cone it can be a real pain if not impossible, you need to remove the insulation, [epoxy] over and around the connection of the tinsel wire to the VC wire and re solder them if the problem is the solder connection, if it is a brake in the VC wire, as long as it's at the connection a little solder can fix it, after repairing re-epoxy the connection to the cone.
CAUSION solder can and will melt/burn a hole in the cone, connection must be lifted clear of cone and something, [that will not melt/burn] placed between cone and connection. Also the repair of the tinsel to VC wire is not easy and will take some skill and a lot of patience. 94
Old Nov 26, 2005 | 10:19 AM
92ehatch's Avatar
Default Re: Infinity sub / repair (fcm)
i think im gonna buy another one, until then i put a audiobahn alum12 in there
only thing is its not mine
my amp is a boss c550 i heard bad things about boss but im really impressed with this amp.
91ed9
Welding / Fabrication
20
Dec 15, 2007 11:59 AM
fergs96integra
Audio / Security / Video
23
May 22, 2006 09:17 AM
97LXAcc0rd
Oct 30, 2005 05:43 AM
Jonathan_ED3
13
Sep 27, 2005 07:12 PM
redteg1
Mar 20, 2002 08:47 PM
