Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hasport axle issues
Old Aug 21, 2018 | 07:29 PM
Jacob Stanicic's Avatar
Default Hasport axle issues
Hey guys,
alright so after going through 3 sets of cheap axles i decided to buy a set of hasports.
been daily driving on them for about a month now and they just started clicking.
its a very quiet click and only happens on hard turns.
Is this click the same click thats associated with worn cv joints or is this normal with performance axles?
should i contact hasport?
thanks in advance
Old Aug 21, 2018 | 10:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Hasport axle issues
What application are you trying to fit axles into ??? How LOW is the car ???
Old Aug 21, 2018 | 11:52 PM
My bad shouldve mentioned, its for a 98 Integra with a b18c5 and gsr box. Its about 1.5 - 2 inches lower than stock.
Old Aug 22, 2018 | 12:06 AM
Aquafina's Avatar
Not normal. Contact Hasport or the dealer you purchased from.
Old Aug 22, 2018 | 10:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I agree with Aquafina... if this is a street driven car with normal front end geometry and is lowered 1.5-2 inches... it should be fine... unless the front end has been really smashed or something.
Old Aug 23, 2018 | 12:11 PM
Hasport's Avatar
before the swap what was the car originally?
so other than going full lock and hearing the axles click how do they drive?
Old Aug 23, 2018 | 09:19 PM
its an LS, so i swapped in the b18c5 with the gsr box using the stock ls mounts, had no issues with the swap. Engine and gearbox are completely stock. They drive perfectly fine, all i noticed was the clicking so far on the outer joints. no vibrations or anything like that
I want to rule out any other possibilities before replacing the axles, any ideas on what may cause premature wear on the cv joints?
Old Aug 24, 2018 | 01:42 PM
Hasport's Avatar
the car is a manual chassis?
i highly doubt there is premature axle wear going on as the axles only make noise when turning hard
you say you went thru 3 sets of axles before? what happened with those axles?
Old Aug 24, 2018 | 06:35 PM
Yep manual. my last 3 pairs of axles met a similar fate, they all started clicking after about a month or so of daily driving. I was told by several mechanics and others on here that i just needed to buy a pair of good quality axles. But now im suspecting that theres something else thats causing them to break, rather than the axles themselves being at fault. I doubt its my suspension geometry so im trying to figure out what's making my car an axle killer.
Old Aug 27, 2018 | 07:39 AM
Hasport's Avatar
so the axles arent actually breaking per say they are just starting to click on hard turns?
Old Aug 27, 2018 | 01:54 PM
right, it gets gradually worse but ive replaced them before it got too bad
HATCH22A
Jan 5, 2010 06:54 AM
srok1
Sep 15, 2009 04:01 PM
Gsr94black
Mar 6, 2009 05:48 PM
JDM SIR-G
Dec 15, 2008 11:18 AM
fred92htch
Jul 10, 2002 02:07 PM
