No Crank - No start
Yes, we need another one of these...
Issue: No crank; no start.
Vehicle Information: 94 Civic, d15b7 engine.
Symptoms: When turning key to position 2, fuel pump primes. Turn key to position 3 to start, click from front (starter) and fuel pump primes again. Started once to a rough idle.
When discovered: Vehicle had a rough idle. Discovered IACV bolt was loose. Stopped engine to tighten bolt; vehicle wouldn’t restart. Replaced starter with a used OEM; same result. Replaced starter with reman: same result.
Diagnostic Information:
Clutch safety is present and verified functional with multimeter. (aka, it wasn’t laying on the floor or missing)
Jumped starter across relay: starter clicks, does not spin to engage flywheel. This should rule out any ignition issues and single out the starter itself.
Engine rotates freely. Push starts fine.
Pulled all fuses under dash and in engine bay - no blown fuses.
Removed starter and bench tested: plunger extends and spins; however there is no load on it while bench testing.
Am I missing something in my diagnostics? Grounds are fine, voltage is fine, battery tested good with load tester. I’m leaning towards a defective starter. I have researched other threads with similar issues, most are unresolved where the OP never replied for the solution. A few I have found indicated faulty reman starters (we all know how AZ and AAP remans are).
I’m open to ideas and other diagnostics.
- Battery Voltage: 12.41v
- Block to ground: .1ohm
- Block to battery: .2ohm
- Tranny to ground: .4ohm
- Tranny to battery: .5ohm
- Battery to ground: .3ohm
- Starter to battery: .4ohm
- Voltage at starter: 12.41v
- Voltage at signal wire when turning key to position 3: 12.41v
Have the starter bench tested.
In the car, if you jump power to the starter terminal it should also crank. If not, I would suspect battery. May be putting out 12.41v, but is not putting enough current to the starter.
I didn't bench test it before I installed it. However, last night I did remove it. I hooked a jumper cable from the starter housing to my negative battery terminal, left the power hooked up, and lengthened my ignition wire. When I turned the key, the bendix shot out but didn't turn. I currently have it in my truck and I'm going to be stopping by advance on my way home.
As for the battery amps, I tested it with a battery tester and the results were good. I even had it at advance last week to get it tested on their machine and it was good. It was kept on a trickle charger.
Replaced starter with a new one. Bench tested it before hand and it extends and spins. Installed in car and: click.
So maybe I'm not getting enough current? I pulled my foreman over and hooked the jumper cables up for a few min, turned the key and the starter turned, but not enough amps to completely turn the engine over.
So I went and hooked up my truck, I still get a click when turning the key. That's what I had before when I assumed that it was a bad starter. Could my batter just be that dead that it won't even let me jump it? It's not rocket science to jump a vehicle, I've done it numerous times before.
Charge the battery from an AC powered battery charger.
Turn the headlights on and watch while trying to start. If they dim way down or go out, the whole car is losing power from the battery. This could be the battery itself or a bad connection at the battery.
I have had the battery charged on a battery charger. When I attach the charger it shows a 25% charge, then isn't fully charged until the next day.
As far as the headlights, I have Denji projectors with HID's installed. I might have to watch the tail lights.
The almost start with my 4 wheeler and no start with my truck is still confusing me.
I'll update this later after work when I get the results. I swear this car knows that when it gets running its going up for sale.
Charged battery overnight, 12.92v
Connected load tester, shows battery is good.
Charged battery again, same voltage. Let it sit overnight: same voltage.
Installed in car: single click.
Rechecked voltage: 12.61v
As far as the headlights dimming, I watched the parking lights, brake lights, and instrument lights; they all dimmed the same.
Battery is 4 years old; still tested good. I'm going to try using my lawnmower battery.... It's also a g51
Edit: lawn mower battery didn't work. Still makes a click
Resolved
Ordered new 4ga ring terminals to make new grounds. Used a dremmel to really make sure everything was cleaned off. No change.
Saw my 4ga going from the battery to the starter and figured I might as well change that one too. Once changed, the car fired right up. Even though it showed proper resistance when checked, it was bad.
It's been idling great for about 10 min so far.
1baddcivicsi
14
Apr 18, 2009 01:14 PM
Jonathan_ED3
Aug 14, 2008 06:15 PM
