Need help on a d16z6!
Old Aug 15, 2018 | 01:29 AM
Sol-Yang's Avatar
Default Need help on a d16z6!
After changing clutch, the clutch springs were really bad, still using same pressure plate and flywheel but flywheel was not resurfaced. After putting everything back on, seems af if clutch won’t disengage. When car is on I can shift gears without clutch without any grinds, pops and car does not lurk/lunge toward. When stepping on gas rpm gauge moves but speedo does not. Axles are in and seated correctly. Slave and master cylinder were bled also. Car won’t move for some reason or engage gears. Idk what it is, any advice is recommended. I already took of transmission 3 times, I want to do it one last time and get it moving if not it’s going to the shop.
Old Aug 15, 2018 | 03:18 AM
tony_2018's Avatar
Fish Twig
Default Re: Need help on a d16z6!
sounds like the clutch pedal isn't adjusted. when you hook everything back up have someone step on the clutch pedal while you verify that your slave cylinder is moving the fork.
how do you know if your vss is getting a signal if you can't even get the transmission into gear? curious.
Old Aug 15, 2018 | 03:23 AM
NVturbo's Avatar
O.G. triple O.G.
if you took it out 3 times, why didn't you replace the pressure plate and get the flywheel resurfaced? Did you use the clutch alignment tool or just stuck something in there?
Old Aug 15, 2018 | 04:49 AM
mk378's Avatar
Always trial fit the new clutch disk on to the transmission shaft before installing, to make sure you have the right one. That can save a lot of frustration later instead of finding the transmission won't go on because the hole is too small, or the car won't move because the hole is too big.
Check for pressure buildup in the line by opening the bleeder on the slave cylinder with no one pressing the pedal. If there is pressure when no one is pressing the pedal, you would have the clutch held out all the time and the car won't move.
It does sound like in this case though it's because you're trying to reuse the old pressure plate with bad springs.
Old Aug 15, 2018 | 02:54 PM
Sol-Yang's Avatar
Pressing on cluch and slave is moving the fork.
Old Aug 16, 2018 | 04:59 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I’ve had my clutch adjusted to tight and had a simular problem before, it held it just enough engaged to not let you move gears while car is running, as soon as I would shut car off everything felt great.
Old Sep 13, 2018 | 12:47 PM
Sol-Yang's Avatar
So before I install my transmission I bought a new flywheel and pressure plate which I’m going to install, my friend had told me that driving with a broken clutch disk, the springs on disk wobbly and about to fall out, could’ve messed up my transmission and that’s why it won’t go into gear. Has anyone ever occurred this problem and could it be a possibility that driving for a while with a bad clutch disk could’ve ruined my transmission and I need another transmission?
Old Sep 13, 2018 | 01:26 PM
tony_2018's Avatar
Fish Twig
That is correct, driving with a broken spring will cause to not be able to shift into gears. Because the spring pops out and lodges itself between the clutch and the pressure plate and keeps it there. You're are force to rev up high to get it into gear but that is a risk as you can mess up your gears. Change the clutch, change the world.
Old Sep 13, 2018 | 05:30 PM
mk378's Avatar
You can check the transmission outside the car by turning the input shaft by hand. It should be quiet and not wobble. Twist and push the shift rod into each gear and watch the output rotate at different speeds.
kaivorth
Honda Civic (2001 - 2005)
Apr 3, 2017 07:17 AM
allshownogo
33
Mar 19, 2009 01:00 PM
ej1vtec
13
Jun 10, 2006 01:33 PM
SlwGsr
Nov 23, 2005 11:23 PM
