Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Power Steering Leak
Old Jul 31, 2018 | 10:39 PM
Zigory's Avatar
Default Power Steering Leak
Hi,
I've noticed some leaks from my power steering reservoir/pump?, it seems to drip more when the car is parked on an incline. After a few weeks it is noticably low and the PS reservoir has some bubbles when I check the fluid level while the engines warm.
One of the hoses connected to the reservoir looks wet with oil, anyone else experience this problem? Thanks
Old Aug 1, 2018 | 06:22 AM
NDNV's Avatar
Default Re: Power Steering Leak
Inlet (suction) O-rings tend to go bad and leak. I bet this is your issue. Replace O-ring.
Old Aug 1, 2018 | 02:19 PM
holmesnmanny's Avatar
ya there are 2 orings that sometimes go bad early, one for the high pressure hose at the pump, and one for the joint at the pump
Old Apr 1, 2019 | 08:21 AM
Zigory's Avatar
I believe it was the o-rings, thank you. Not sure if I got the wrong ones but it didn't quite seal so I used two and then sealed it with some silicone gasket stuff. Also does anyone notice when starting their car the idle will lower a bit, then find a steady place? I read somewhere here it may be related to the power steering.
91akira
Jul 27, 2017 10:16 PM
nexusRawr
Nov 14, 2016 06:22 AM
jonyi27
Acura TL, RL & ZDX
Jul 26, 2015 04:19 PM
darcane
Apr 24, 2014 08:08 AM
fackyou
Aug 6, 2006 01:29 PM
