The trim molding below the control panel should be removed first. Usually, it is to gently pry off (with non-marring pry tool) the trim molding (held in with plastic clips) at the bottom of control panel to expose the two screws on both sides. (Sometimes the trim can be pulled out by hand. I believe it is only clips holding the trim; double check though.)
Remove the two screws on both sides of the control panel, then pull out the control panel which is held in with more plastic clips. Disconnect electrical connectors.
The trim molding is not shown in this parts diagram; but, the rectangular openings at the bottom of the panel is where the plastic clips of trim molding fit into.
