I got a rod knock
Old Jul 23, 2018 | 11:54 PM
Dennis237's Avatar
I got a rod knock rebuild the short block about 1000 miles ago any chance that I could just replace the bearing?
It's a Ls block with gsr head. Short block was rebuild at a machine shop.
Old Jul 24, 2018 | 04:03 AM
2x0's Avatar
2x0
10 Year Member
Default Re: I got a rod knock
How many threads are you going to start to ask the same question?
Old Jul 24, 2018 | 05:29 AM
K20.ek's Avatar
yes just measure and replace the bearings with oem bearings
Old Jul 24, 2018 | 07:44 AM
Dennis237's Avatar
my bad first this using this
Old Jul 24, 2018 | 05:33 PM
Dennis237's Avatar
So I dropped the oil pan and all the bearings look good so now I'm thinking it could be the connecting rod. When I had the block decked I had them install itr pistons. Anyone ever had issues with this? I had oil in it. It has never over head no smoke. I' was still breaking this in. Anyone one know how to check the connecting rods with out actually pulling out the piston
Old Jul 24, 2018 | 06:33 PM
Aradin's Avatar
Premium Member
You can use a long screwdriver or long 1/4" extension in the spark plug hole to check and see how high each piston comes up at TDC. Take the plugs out and turn the engine over by hand, check one cylinder at a time. If one comes up short, even slightly, it's a good indicator of a bent rod. Who rebuilt the block? What type of wrist pins were used?
Old Jul 24, 2018 | 07:21 PM
Dennis237's Avatar
I got the it rebuild at a shop in east LA. He said he used stick pins. I will check the pistons in the am and update you guys. Thanks for the help. I'm sure it's the pistons and connecting rods due to the fact that there is no metal shavings and it had oil.
Old Jul 24, 2018 | 08:18 PM
K20.ek's Avatar
I would take it back to them and make them fix it.
TravisBiggie
May 27, 2013 07:28 AM
Johnnytech
Jun 1, 2004 08:34 AM
ill_take_one
Feb 22, 2003 07:40 AM
