Rod Bearing question
Old Feb 21, 2003 | 02:24 PM
ill_take_one's Avatar
Default Rod Bearing question
Guys, to make a long story short, i found out today that my rod bearings are going bad. There's an audible knock at low rpms.
Here's the dilema:
I WILL be buying new rods/pistons soon for my turbo build up. Is replacing bearings that big of a deal? Can it cause MAJOR damage if not taken care of right away? THe tech there said i'd be fine for awhile (define awhile) as long as i didnt rag on her too much.
Any suggestions??
Should i replace them now, or should i wait to replace them when i get my rods/pistons?!?! Should i go ACL, or honda OEM bearings??
Could my block be damaged if i let go too long??
Thanks!
Old Feb 21, 2003 | 08:40 PM
Flamenco-T's Avatar
Default Re: Rod Bearing question (ill_take_one)
I'd do it right away as soon as you can....you don't want your rod bearing to seized up and put a masive drag on the rod journal...it may cause the rod bolt to back out and eventually the rod cap may back out and threw a hole in your block...
stan
Old Feb 21, 2003 | 09:15 PM
b16ahybrid's Avatar
Default Re: Rod Bearing question (Flamenco-T)
stan
or cause excessive wear on your crank. Since your replacing your rods and bearings they will be fine...i'm just concerend about your crank getting excessive wear.......thats expensive to replace
Old Feb 22, 2003 | 07:24 AM
Default Re: Rod Bearing question (b16ahybrid)
Alrighty, thats what i've been hearing from other people too.
Someone said though, that i could replace these by jacking up the car, taking the exhaust manifold off, and oil pan, then the rod caps? Can i actually replace them by doing it that way?!? sounds fishy to me...
I need some damn good prices on rods/pistons. eagle/je or arias. know of any dealers on this site that have LOW prices/!?
Thanks!
Old Feb 22, 2003 | 07:40 AM
ekb18c's Avatar
Arias pistons here. $475 shipped for shelf items.
5genhatch
Engine Machining & Assembly
May 27, 2019 08:48 AM
bdubnyc
K Series
Aug 9, 2009 04:40 AM
tdizz07
Oct 27, 2006 08:24 AM
Mad Cow Disease
Oct 2, 2003 01:55 PM
Sonny
Aug 23, 2002 08:06 PM
