Need help with 1990 civic timing!!
Old Jul 16, 2018 | 10:21 PM
1990civicdx's Avatar
Default Need help with 1990 civic timing!!
Is the timing pointer on the belt cover suppose to match with "RED" Line or "White"?
Old Jul 16, 2018 | 10:27 PM
Default Re: Need help with 1990 civic timing!!
*Match with "Red" Line or "White" on pully?
Old Jul 17, 2018 | 05:57 AM
jlicrx's Avatar
depends on what you are doing - the white mark is for TDC and the red mark is used for ignition timing - if you are installing the timing belt, the white mark lines up with the pointer - if you are setting the ignition timing, the red mark lines up with the pointer, unless you are using a digital timing gun where you can input the desired degrees of timing into the gun - with the degrees (say 18) input into the gun, you line the white mark up with the pointer
Old Jul 17, 2018 | 06:13 PM
acmoc's Avatar
white line is for mechanical timing(top dead center) with cam gear
red line is for ignition timing.
My crx hood label says 18+- 2 degrees
My timing light looks like this
And I set the **** to 18 and line up the red mark.
I know this is correct because in California, the emissions test, test the timing. And mine is consistently at 18+-2
blackbndt
Oct 4, 2009 10:20 AM
lilshady6796
21
Mar 31, 2009 09:18 PM
sohc-8
Dec 26, 2005 04:19 PM
King_j
Aug 14, 2003 07:40 PM
integrasi
Jul 23, 2003 04:26 PM
